Question about Sewing Machines
Looping of the bobbin thread Janome - Sewing Machines
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
  • 30 Answers
SOURCE: Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Posted on Jan 24, 2009
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
Mimito7
  • 128 Answers
SOURCE: machine will not pick up bobbin thread
Sounds like your needle is in too far and it not allowing the needle to go down far enough to pick up the thread.
Posted on Apr 20, 2009
I have a Janome magnolia 7318. when I lower feed dogs to quilt it will not sew circles or feathers well. It pulls bobbin thread up on top in loops.
I've found that when FMQing, I usually need to increase the bobbin tension to keep the bobbin thread down (for this reason, I have a separate bobbin case that has the tension adjusted that is used only for FMQ). You may even need to decrease the top tension if the top thread is "pulling" the bobbin thread up.
Jun 18, 2017 | Janome Sewing Machines
Using a new Janome MD4. Monogram stitches looping on top when lettering is narrow and then bunches up top thread in bobbin case.
Word to the wise... Thread loops on top, the problem is with the bobbin. If it loops on the bottom, the problem is with the tension.
May 01, 2014 | Sewing Machines
Thread loops while I sew
i should know whether the loop is upside or downward, its opposite tension adjustment , if the loop is downward position, tighten the upper thread tension , if the loop is upward then tighten the lower bobbin tension
Feb 27, 2014 | Janome Memory Craft 9500 Computerized...
Top thread is looping and machine gets locked up. already rethreaded and checked for thread buildup. machine is a janome dc1050
try a new needle
adjust the top thread tension
make sure the bobbin is inserted the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
Aug 08, 2013 | Janome Sewing Machines
When i sew, the underneith is making loops
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | Janome Memory Craft 9000 Computerized...
I have a janome 1600, my third is looping on the bottom
Feb 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
I just bought a memory craft 6600 the thread from the bobbin keeps looping on the top fabric? When I change the tension number it just gets worse Help
Check your threading, especially your bobbin because usually looping on top means the bobbin is not set right, Read your manual,
Aug 24, 2010 | Janome Memory Craft 9000 Computerized...
Janome 4800 mc looping underneath
Un-thread the machine.
Remove the needle plate and carefully inspect the bobbin case for any nicks in it. It is made of carbon fiber and can be lightly polished with 1500 grit sandpaper.
Place the bobbin case back in making sure that it rests in the proper position. (In the 5 o'clock position is a bumper to prevent the bobbin case from twisting too far.)
Thread the machine making sure that the take-up lever is threaded.
Set the upper tension to AUTO.
Use Mettler or Gutermann thread for good results.
Jul 12, 2009 | Janome Sewing Machines
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
11 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
