Question about Hunter Ceiling Fan Light Remote Control
Remote changes all ceilings fans
I have just installed Hunter Fairhaven fans in my home. My issue is the remote for one changes all the others at the same time! Is there anything I can do to resolve this and keep the fans?
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Posted on Jul 03, 2009
hondakilla
  • 129 Answers
SOURCE: Have hunter ceiling fan without a visual switch on
http://www.hunterfan.com/doc_search_results.aspx?search=28870
Posted on Aug 23, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
My hunter fan light can't be turned on/off with the light switch
The switch will only turn the power on to the fan/light. You have to use the remote to dimm the light & change the speeds. You should be able to install it on the wall next to the switch so you can turn on your light when entering the room.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
I just installed a hunter ceiling fan with light & remote control but the fan will not shut off or change speeds
Sorry for this::::You may not have the correct remote for the fan.
The fans are difficult to install.
Kudos to you,Sir.
Nov 13, 2012 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter Fan with Remote
Contact Hunter Fan and they will send you another ceiling remote. Just received mine but have not installed yet. Good luck. Len
Apr 27, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
