Question about Panasonic CQ-R111U Cassette Player
Panasonic R111u wires are all green. Which is which?
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Dec 31, 2008 | Panasonic CQ-RDP162
I'm trying to wire up my panasonic dp33 car c`d player but i've lost the schematic to tell me which wires are which speaker. Can you help - the rear speaker wires are violet and green and the front ones...
White is front right, front left should be gray, left rear is green and right rear is violet. The yellow wire should be a constant 12V, red switched 12V(on when key is on). Black to ground. You've likely figured some of that out already. If you need more info let me know.
Oct 10, 2008 | Panasonic Car Audio & Video
Panasonic cq-c3100u
scottmar7- You need the wiring diagram for your panasonic deck,the diagram is as follows.
red- 12volt key switched
yellow-12volt constant-memory
black-ground
white-left front positive
white with black stripe-left front negative
grey- right front positive
grey w/black stripe-right front negative
green-rear left positive
green w/black stripe-rear left negative
purple-right rear positive
purple w/black stripe-right rear negative
blue- remote turn on- for amplifier
These are all the wires you should need,to hook up you deck.
If you need anything else let me know,I can help you,happy listening. cooltek mar,14/08
Mar 14, 2008 | Audio Players & Recorders
Panasonic CQ-R111U Cassette Player Logo
71 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
