Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
A O SMITH CENTURY - AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
How to replace seal on century lasar spa motor
split the motor from the wet end then take off the cover to the impeller remove screw for impeller backwards thread might have to hold the shaft on the back of the motor then unscrew the impeller regular threads separate the motor from the backing plate replace seals then reverse process
Jul 05, 2014 | AO Smith A O Smith Motors Century 1hp 115v...
What part number for an impeller seal century 193262
To size or locate an impeller, you need PUMP information, NOT Motor information!
Jun 08, 2014 | AO Smith A O Smith Motors Century 1hp 115v...
Century 1081 wiring to external capacitor
You are correct in assuming Hayward won't be of much help. A.O. Smith used to be original equipment on several brands of pool pump motors. Over the years Century/Magnatek took the business away from A.O. Smith, so A.O.Smith bought Century!
Most pool pumps have a 1081 designation on them. It has been a while but I think that means it is rated for continuous duty (24/7).
I'd call a local motor shop, they rebuild these things all day long.
Mar 02, 2013 | Pool & Spa
Replace ao smith century centurion b852
take apart normally impeller screw backwards thread but impeller unscrews normally
Oct 20, 2012 | AO Smith A O Smith Motors A O Smith 3/4hp...
Impeller and housing resemble
Download the AO Smith Motor Troubleshooting Guide below (a.k.a "#3400" from aosmithmotors.com) below:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=588
Jun 19, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
26 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
