Question about Daewoo DVDRW11 DVD Recorder
Connection Nightmare I have a Sony Bravia lcd t.v, built in digital tuners and a sky box receiving the free to air channels only (no sky subscription it just gets more expensive every ) I bought a Daewoo DVD recrder to hopefully record the Freeview channels from my Sony using RF output from tv to RF input on joy Then tried recording from the Sky Box using scart VCR out to De-coder scart input on DVD....No Joy. In frustration I purchased a seperate Freeview box connected just to the DVD RF input and Scart output you've guessed no joy.For some reason when I tune the DVD to an input it finds the same channel on 30 different points...........HELP
  • 1,463 Answers
Re: Connection Nightmare
Try here in this forum
they will give you some ideas t oconnection set up .
Posted on Nov 02, 2007
0 characters
3 Points
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
Do I need to throw out my GoVideo because it is not digital. Comcast recently went all digital and I cannot get any response on my VCR. Channel 3's view stays consistance from the TV Channel and doesn't...
Not if the unit itself still works; that is, it still plays videotapes and DVDs (with picture and sound).
Check your TV, you may have the wrong input selected for your unit (and/or other connected devices), or the TV is on the wrong channel; hence why you can't see anything from the VCR.
As for the ComCast box, give them a call and ask about it - quote the box number, and ask if it is digital or analogue - if it is the latter, they should replace the box free of charge as part of your cable subscription.
You do not need a new combo unit, unless you want one later which has a digital tuner. All it means is that you have no analogue TV channels in your combo unit.
Apr 04, 2011 | GoVideo DVR4200 DVD Player/VCR
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
I've an LCD with built in digital tuner, how do i
No the Tuner doesn't have an Output, so one cannot get a signal OUT of the Tuner, UNLESS there is a Tuner Out, A Monitor, OUT. Then you cannot get any signal to feed into the device you wish to record with. The signal MUST go to a TUNER first, then the OUTPUT may be fed to anything else. As said IF the Device with the Tuner HAS a way of outputting Video & Audio, then you can take that signal and record it, otherwise you cannot.
Mar 30, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
Thomson DTH 7000 DVD hard disc recorder
there is no digital tuner built into this unit as I own one
Jun 06, 2009 | DVD & Blu-Ray Players
Do I have digital tuner?
No, this set does not have a digital tuner. The TV must be an HDTV in order to have a digital tuner built in.
Dec 31, 2008 | Sylvania 6720FDF
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
<A href="">
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Daewoo DVDRW11 DVD Recorder Logo
218 people viewed this question
Top Daewoo DVD & Blu-Ray Players Experts
Martin Murray
Jaime Hernandez
Are you a Daewoo DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
