Question about Radio Communications
Pairing a utel h52 bluetooth headset with lg optimus f6 phone
sandrew
  • 2961 Answers
SOURCE: LG HBM 300 Bluetooth headset
Normally the default password for headsets is 4 zero's 0000, unless you have previously set one with the phone.
Posted on Sep 05, 2007
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Posted on Jul 13, 2008
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Posted on Apr 12, 2009
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
I can not configure Backbeat 903 + with android LG Optimus 509
It sounds like you need to prepare your phone to connect to the headset. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on. Make sure there isn't any other bluetooth interference and then pair the two devices following the instructions from the user guide in the link below for the Plantronics Backbeat 903+.
Plantronics Backbeat 903+ User's Guide
Good luck from Headsets Direct!
Aug 30, 2011 | Plantronics Backbeat 903 Bluetooth...
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
Bluetooth headset now will not pair up with my LG enV
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 20, 2009 | OEM Systems Motorola Bluetooth Headset...
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
After putting the headset into pairing mode, my phone (also an LG) will not recognize and pair with headset. Also tried another (non LG device) and that would not pair either? Headset used to work with...
According to a VzWireless Tech, take the battery out for 30 seconds and then put it back in. The phone should reset itself to pair the bluetooth headset with the phone. If that does't work remove the device from the phone and start from step 1. I removed the device from the phone then I took the battery out for 30 seconds. Then I paired the bluetooth and followed the next steps to complete the sync.
Jun 05, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Connecting to my phone
With many phones you have to have the phone in the bluetooth search mode, before you put the headset into the pairing mode.
Aug 31, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM Bluetooth
headset cannnot pair too two phone at the same time
May 07, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Mar 31, 2008 | OEM Systems Bluetooth Headsets - Model...
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
