Question about Amana NFW7300WW Washer
How do you chang tub bearing viedo - Amana NFW7300WW Washer
  • Amana Master
  • 5,323 Answers
Try youtube put in ur model and what u want todo
Posted on Apr 11, 2015
How do i change the tub bearing on a LG front load washer?
Unless you are a skilled DIY person, I do not recommend that you try to replace this tub bearing on the washer yourself. One has to virtually strip the entire machine to remove the tub to accomplish this bearing replacement.
If you are skilled, then please supply the model number of your machine.
Oct 11, 2014 | LG WM Washing Machines
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
How to change the bottom spin bearing?
Two bearings in that model One in tub will be leaking water if bad. One on the lower end of transmission.which is part of the transmission. Whole tub basket unit must be removed from the case to replace either the tub bearing and seal or the transmission.
Nov 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Need to change tub bearings
If you need to change tub bearing, then you also need to change the seal. It is over $300.00 fix, it depends how old the machine is, if old go get a new one
Jan 13, 2010 | Washing Machines
Need to change tub bearing on frontload neptune model mah300wwa 2nd.year productoin
That bearing is part of the outer tub and is a big job.
you can get a diagram here . The bearing is not shown because it is part of the outer tub.
I would verify that if you decide to do this. but I remeber doing just one and it was a $600.00 Job, Of course that was with labor. the tub itself is over $425.00
the model # I used was mah3000aww
Jan 13, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Problem with my Whirlpool 9250 front load washer
The problem you are having can be caused by one of 3 things. The pulley on the back of the tub can be slipping in the hole that it fits into. The main tub bearing that the tub rides inside of is defective, or the tub support on the main spin basket is broken.
Reach inside of the washer and give it a turn. If the basked seems to fall when it turns one of these 3 items is the problem.
There is a rear bearing that you can change and you can also change the rear pulley. These two are the only 2 that you would consider repairing. The inner rear bearing or the main tub support are not cost effective to repair.
Unplug the washer, then take the back off and you will see the pulley with the belt going around it. make sure it is stable. You can remove it by taking off the large nut that is holding it in place. Then the pulley will pull off. Behind it you will see the rear bearing. On some models this bearing is not replaceable from the rear. Check to see if it is possibly damaged. If the bearing looks good, you will probably need the main tub. I do not recommend repairing if it needs the tub. The job would cost in the $600.00 price range. Good luck and send me more information if you have it. Thanks for requesting me.
Mike Anderson
Jan 29, 2009 | Whirlpool GHW9250M Front Load Washer
Tub bearing kenmore front loader
you have to change the whole outer tub that is the only way you can get but take off your top by taking the screws out of the back and then it slides back then see if the noise is coming from the back center of the tub if so if will need to be changed and the tub is expensive
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer tub seal bearing kit - grease?
how do i change bearings and shaft ona maytag washer model# mvwb300wq0
Jun 17, 2008 | Washing Machines
Amana NFW7300WW Washer Logo
42 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
