Question about Sub-Zero Refrigerators
Reset subzero condensor code - Sub-Zero Refrigerators
2 Suggested Answers
  • 4 Answers
SOURCE: how do you reset the fridge to remove the vacuum
You have to press the unit off button inside of the refrigerator and then press it again to turn the fridge back on. The light should go away after that
Posted on Jul 28, 2009
The condensor is clean, but the vacum condensor lights keep coming on. What do I do?
when "vacuum condenser" or "service" lights r on, it means compressor is running more time than desired. most common issue that freon leaks out at evaporator in fresh food section. thats the most common issue with all subzero models. Hope thats helpful.
Jun 13, 2014 | Sub-Zero 650/SRH Stainless Steel
How to vacuum condensor on Sub-Zero Model 650 ?
remove upper grill condensor will be on right take vacuum us the furniture attachment and clean if you are getting an vacuum cond. light on display you will need to call a servicer my number if you are in the dallas metro area is 8178515057 if not you can find a local servicer by going to factory web site subzero .com
Apr 18, 2012 | Refrigerators
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
How do you reset the fridge to remove the vacuum condensor light on our subzero 690 refrigerator
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
690 SubZero Side-by-Side Fridge
You need to reset the controller open the door and press and hold the "Bell" looking symbol for 15secs then release it should go away let me know if that worked
Jan 26, 2008 | Sub-Zero 690 Side by Side Refrigerator
Hi...need help...subzero 550
Make sure the condensor is clean, blow some Air though the Condensor to make sure good Air flow towards Compressors. also, you might have a bad defrost timer or Freezer Control... worst case you might have a bad Compressor... hope I can help....
Jan 16, 2008 | Sub-Zero Bottom Freezer Refrigerator
Subzero model 650 needs the condensor cleaned
The best way to clean the condensor coils on this model is to blow it out with an air tank.
Jan 07, 2008 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
