Question about Samsung AW1203B Air Conditioner
"Ch" is displayed on the display
I also had the same problem... the display showed "Ch" i pressed the up and down arrow keys for few seconds and then the "Ch" went off... but i am not sure why it was displaying "Ch" is it only an indication to clean the air filter or an indication of some other problem in the AC...??? does somebody knows what "Ch" indicates..??? do i need to call the samsung technicians...???
  • gemmaddox
    gemmaddox Sep 26, 2012
    yes cleaned filters not dirty,pushed plus-minus held 2 min,still not, turn off ,pluged in ,same code
  • gemmaddox
    Its a LG ptac unit
HI!
Appearance of "Ch" on the AC screen is an reminder to clean the AC filter. Whenever it appears you clean the filter and connect the AC to power but, do nut run it is (it should be in switch off mode but, connected to power).
After that press the up and down buttons together on the control panel of the AC (not on the remote) till a beep comes from the AC.
anirudh
Posted on Sep 07, 2010
  • 1 more comment
  • sudipmaitra Jun 05, 2011
    I spoke to the Samsung Customer Technical Support Team and they informed me that the Ch appears as a reminder to clean the AC plastic filter. After that is done the Ch sign still remains on the display. This is normal. To get this off (now that the filter has been thoroughly cleaned) is to press the up and down button on the AC (not on the remote) for 4 seconds. The display will then disappear. It worked fine for me. Samsung also confirmed that this is no sign of a malfunction of the AC but just a reminder.
  • Parshva Doshi Jul 23, 2012
    Hi I have a question.....my AC panel is not working....so now I have only a remote...is there a way by which I can remove it !!!!
  • rishidoshi
    rishidoshi Oct 18, 2012
    My AC panel is also not working. i cannot reset the CH. any ideas?
  • 10,515 Answers
just press the arrow keys up down and hold it for few sec till beep comes..(on ac scree not on remote)... this indicates cleaning of air filters..
If problem still persists, let me know.
Thanks.
Posted on Jun 19, 2009
  • 1 more comment
  • faiaz16 Oct 27, 2010
    hi thanx man, it worked
  • yatan Apr 27, 2011
    nope did not work.Tried according to manual...no beep...displays 'ch'.Help.
  • sammalhotra2 May 24, 2011
    my display panel is not working. is there any other way of removing ch?
    thanks
My display is not working anymore. now how i can reset it and its all the time showing "ch".is it harmful to run ac on this mode/
Posted on Apr 18, 2011
What is the pin code for Aiwa HVFX5500 vcr
hi ,
Try...
Power on,
Press both CH/UP key and REC/OTR key for more than 2 seconds,
OK will appear in the display panel.
or try
Press CH DOWN key on VCR while pressing the 7 key on remote and hold for more than 5 seconds.
The display should then show OK.
but First disable the child lock by pressing the "lock" button on the remote,
and only then press "Ch-" and "7".
Oct 02, 2014 | Televison & Video
How to change language
Turn on the printer.
"Ready" on panel display.
Press "Menu" key.
Press the Up or Down Arrow key to show "Language."
Press the Enter key. "Language: *German" shows on the panel display.
Press the Up or Down Arrow key to get the language you want.
Press the Enter key. "Menu" shows on the panel display.
Press the On Line key. "Ready" shows on the panel display.
May 30, 2014 | Ricoh Aficio SP C410DN Laser Printer
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
Printer stops printing while data still in buffer
I would suggest the porblem may be associated with Bi-Directional Communication.
Bi-Directional Communication can be turned off on the 6312 in the following way;
o Set the printer to Offline.
o Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On)
o Press the Mode key: display will show Offline Normal.
o Press any Arrow key until display shows Offline Config.
o Press the Forms/1 key.
o Press any Arrow key until display shows Config Paralel.
o Press the CPI/2 key.
o Press any Arrow key until display shows Paralel Bi-Dir.
o Press the LPI/3 key.
o Press any Arrow key until display shows Bi-Dir Off.
o Press the Enter key and the interface will be set.
o Press the Clear key.
o Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off)
o
This would need to be saves to your configuration so this setting is not lost when you power the printer OFF, of if the printer is reset.
You should also be able to access a Web Page on the Axis Print Server and will be able to change paralle interface settings set this to Uni Directional or disable Bi-Directional Communication
Dec 06, 2011 | TallyGenicom 6312 Matrix Printer
My samsung window ac ,at the display showing ch ,what does
It is not a problem it is just the reminder to clean the filter of the a/c this error display automatically every after 336 hrs, so just clean the filter and reset the CH display by pressing temp up and down arrow key to reset it
Jun 22, 2011 | Samsung AW1203B Air Conditioner
How do you increase the display from a dim display
Press and release the 2ND key. Press and hold the up-arrow key for a few seconds. If you go too far, repeat the process using the 2ND and down-arrow keys.
Aug 25, 2010 | Texas Instruments TI-82 Calculator
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
Press the show key (top right arrow)
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
Dec 23, 2009 | NorStar M7310 Phone
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press either Arrow key until display shows Test Diag.
Press either Arrow key until display shows Diag Prnt Cal.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Sep 11, 2009 | Tally Line Matrix T6100 Printer
Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Jul 22, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
"CH" is only getting displayed in A/C
shilpi,
mayank
Apr 11, 2009 | Samsung AW1203B Air Conditioner
Samsung AW1203B Air Conditioner Logo
2,275 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
