Question about Danby DDW1899WP Portable Dishwasher
Whirlpool dishwasher lock
Aluminum lock for transit will not come off
Dishwasher WHIRLPOOL DU930PWPQ2 stays locked and doesn't start. Even when i push on "heated dry" during 5 seconds. What can i do ? Some one gets an answer ? Thank you
washer Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check yourself ... Frigidaire, Kenmore, Whirlpool, and Bosch) work the same way. ... This door switch is also sometimes called a door lock or door interlock switch. ... All the lights light up on my dishwasher but the thing doesn't turn on at all.
Troubleshooting Why the Dishwasher Won't Start ... - YouTube
? 3:58
https://www.youtube.com/watch?v=8ZrtcdtmyEk
Jun 20, 2012 - Uploaded by PartSelect
In this video you'll learn what happens when the dishwasher won'tstart. ... Here are a few things you should check if yourdishwasher won't start: ... Replacing the Thermal Fuse & Harness (Whirlpool #675813) - Duration: 6:01.
Whirlpool Dishwasher DU930PWPQ2 Troubleshooting ...
Jan 14, 2016 | Whirlpool Dishwashers
I have a whirlpool gold dishwasher. The controls locked light is on and I can not get it to shut off. I can not run the dishwasher
In reading the manual, it shows the following:
To turn on Lock, press and hold Control Lock for at least
3seconds.
To turn off Lock, press and hold Control Lock for at least
3seconds.
Jun 07, 2015 | Whirlpool Dishwashers
Whirlpool Gold quiet washplus dishwasher Red Light staying on--control locked Cannot get it to run, no buttons will do anything
Which model dishwasher do you have? The Control Lock is a feature that keeps a child from starting the dishwasher when it shouldn't run. The Cancel button will work but not the Start button.
On the DU920QWD, to toggle the Control Lock off, press and hold Air Dry for 5 or more seconds. (Holding it again will turn on the lock.) Most dishwashers will have a the Control Lock key labeled with text in a small font for how to enable the Lock. The direct link to the DU920QWDB4 manual is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203376817.pdf .
For other Whirlpool dishwashers, the Control Lock sequence will be listed in the manual. You can get a PDF of many Whirlpool appliance manuals from http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Enter the model number (from the rim inside the unit) and click on the right arrow.
I hope this helps.
Sep 08, 2011 | Whirlpool Dishwashers
Dishwasher stopped midcycle and the fuse is not tripped
Some dishwashers work the wire nuts loose in the connection box. Especially those that
are wired to aluminum wiring (these require the purple "IDEAL" brand wire nuts).
Make sure to secure power to unit before servicing.
Mar 06, 2011 | Whirlpool Gold GU2475XTV Builtin...
My whirlpool dishwasher clean light blinks on and off,and I can no longer run dishwasher.Unit is only 3 to 4 years old
Hi- One of two things- fault in touchpad/control, or bad motor. If you pull bottom kick panel, with a bright light look underneath for water deposits on botom of aluminum motor case. Any motor seal leak will show up here. If you see any crud on bottom, motor must be replaced. Not uncommon to fail 3-4 yrs.Anyway- motor is about 100$ - control 150-175$ Labor varies.- Hope this helps- ED
Mar 01, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
My daughter has a Whirlpool series 930 dishwasher and it is locked? How do I unlock it?
This just happened to me recently on my Whirlpool. My dishwasher indicates that the "Air Dry" button will lock it out if held in for 5 seconds. To unlock it, hold this button in for another 5 seconds or until the lock out light goes out. Hope this helps.
Aug 10, 2009 | Whirlpool DU930PWS Built-in Dishwasher
I have a Whirlpool Dishwasher and it is locked and I don't know how to unlock it
I have a Whirlpool dishwasher & locked mine by pushing the "Air Dry" button for about 5 seconds. To unlock it, I pushed it in again another 5 seconds and the unlock light went out & it worked fine. Whatever button you locked it with originally (if you know), should unlock it when held in again.
Jul 16, 2009 | Whirlpool Dishwashers
The Controls Locked button is on and nothing works on my whirlpool gold builtin dishwasher. HELP!!!!!!!!!!!!!!!
Most whirlpools you just hold lock button for a few seconds and it will return to normal function.
Apr 21, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwaher
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more).
Jul 30, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Danby DDW1899WP Portable Dishwasher Logo
16 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
