Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Proheat 8910, just used once, pump belt keeps breaking. I replaced it two times, there is a burning smell and then when I look at the pump belt, its broken.
SOURCE: bissell proheat self propelled series
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
Posted on Sep 27, 2008
jyackle5
  • 8197 Answers
SOURCE: belt manual
Here is the manual. on page 17 tells you how to change.
http://dl.owneriq.net/2/23cae7f7-686f-47c1-8efe-3a106fffcd50.pdf
Good Luck and Please Rate FixYa!
Posted on Jan 11, 2009
  • 3 Answers
SOURCE: brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Posted on Jul 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
http://www.govacuum.com/biclandpobar.html
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
http://www.fixya.com/support/p49887-bissell_6594_powerforce_bagless_upright#manuals.
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
GoVacuum
Posted on Mar 23, 2010
heatman101
  • 43501 Answers
SOURCE: cannot figure out how to install brush belt on a bissell proheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twywt
Posted on Sep 30, 2010
Will not pump water out on the carpet when cleaning
That means that you need to replace the pump belt. Her is the belt you need and the manual:
Bissell 8910 Belt and Manual
Jan 10, 2010 | Bissell 8910 ProHeat Clear View Upright...
Change belt on proheat bissell 8910
I have added a link for the owners manual for your model and a link for the replacement belts you need.
8910 User Guide (PDF)
Bissell Proheat 8910 Replacement Belt
Oct 30, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell proheat model 8910 water will not come
  • check pump belt
  • seat tank properly
  • check tank filter
i have repaired many of these and found that 90% of the time its the pump! #41 on diagram < click
9% its the heater clogged up #65 on diagram < click
1st check the small problems i wrote above
if all else seems fine start by removing the heater and disconnect the hoses from it. blow through one end of the heater (should be no restriction)
Oct 08, 2009 | Bissell 8910 ProHeat Clear View Upright...
Cannot figure out how to install brush belt on a bissell proheat
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
Belt manual
Jan 11, 2009 | Bissell 8910 ProHeat Clear View Upright...
My bissell proheat pump belt....
heatman101
fdjh
Nov 21, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
239 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
