Question about 2001-2011 Ford Explorer Sport Trac Flipping Bed X-Tender HD MAX by AMP
How many quart of transmission fluid does it take to fill automatic transmission and torque converter in a 2001 ford explorer
    Sergeant:
  • 253 Answers
Probably about 10 quarts. Just keep checking the level with the dipstick, you don\'t want to over fill it.
Posted on Aug 14, 2014
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
2006 Ford Explorer Automatic Transmission requires servicing at 60,000 miles. Does it require Mercon or Mercon V fluid and does it require 11 or 13 quarts?
Every Ford after 2001 requries mercon V and alldata states 11 but i would put 10.5 then bring the car up to operating temp and fill as needed
May 18, 2011 | 2006 Ford Explorer
I need to know how many qts of transmission fluid goes in a 1998 ford windstar?
Application: With automatic transmission
AX4S transmissionTotal refill - 12.3 quarts.
May 10, 2011 | Ford Windstar Cars & Trucks
How many quarts of trans missision is in the car
For an 1995 ford explorer 2WD the transmission capacity is 9.5 quarts. It includes the torque converter also..
For an 1995 ford explorer 4WD the transmission capacity is 9.8 quarts. It includes the torque converter also..
Dec 07, 2010 | 1995 Ford Explorer
How many quarts of transmission fluid goes in a 2000 ford explorer /
Hello there
abar_a.gif?v=72006
2000 FORD TRUCKS EXPLORER 5.0L 8-cyl Engine Code P
FILTERS
AMSOIL Ea Oil Filter.........EAO11
Wix Oil Filter.........51372
AMSOIL Ea Air Filter.........EAA122
Wix Air Filter.........46253
Wix Fuel Filter.......33595
Wix Trans Filter.....58955 [1]
[1] 4R70W
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........15.0 quarts
Automatic Transmission, Others Initial Fill..........3.9 quarts[2]
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2]
4R70W..........14.0 quarts
2wd ..........10.0 quarts
4wd ..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, Rear..........5.7 pints[3]
Differential, Dana 35 Front..........3.6 pints[4]
Transfer Case,Full-Time 4WD..........2.7 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
3. Fill to no more than 1/4 to 9/16" below fill plug hole.
4. Fill no higher than 9.5 mm or 3/8" below fill plug.
Aug 07, 2010 | 2006 Ford Explorer
I need to fill the transmission fluid on my 1989 Ford Festiva.
use a very small funnel placed into the dipstick tube check frequently with the dipstick so you don't overfill
May 25, 2009 | 1989 Ford Festiva
Automatic transmission service
yes the transmission has a pump inside of it and will fill the converter just make sure that you get the right amount of trans. fluid in it it will take more that if you just replaced just the filter.
Mar 06, 2009 | 1999 Ford Explorer
My 2001 ford galaxy automatic does not at all go well i can be drive along and if i accelerate a bit harder it seems to slip out of gear and jump people have told me i need a new gearbox others say it...
what i would try first is a transmission flush. not just a transmission service where 3-4 quarts of fluid is replaced but all of the fluid. you could do this yourself and at the same time replace the filter. drop the pan and change the filter, then remove the bell housing plate and locate the drain plug on the torque converter. allow all fluid to drain. reinstall drain plug and pan, and fill with fluid. there are also some after market transmission additives that can restore some of the original ooomphh. good luck
Nov 25, 2008 | 1991 Ford Explorer
Ford aerostar automatic transmission repair
Lay it down flat and fill it about half way about 3-4 quarts. then install it onto the input shaft. Since the torque converter is part of the fluid drive system it will regulate its on its own when the rest of the fluid is added after the install. Hope this helps ~ Zach
Jun 15, 2008 | 1994 Ford Aerostar Extended
2001-2011 Ford Explorer Sport Trac Flipping Bed X-Tender HD MAX by AMP Logo
64 people viewed this question
Top AMP Research Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an AMP Research Vehicle Part and Accessory Expert? Answer questions, earn points and help others
