Aor 8600 like to reset Aor 8600 MK2 to factory default ( All memory need to be erased) I can't add or delete any frequency
  • 19 Answers
SOURCE: How to reset the cisco switch to factory default?
When you say you were able to connect to the switch through hyperterm, were you able to login with the enable password? If not, you cannot reset the factory defaults without the enable password. If you do not have this then search on Cisco's site for password recovery for your model switch. If you did login with the enable password, the command to run for CATos is "clear config all". For Cisco IOS, you have the right command with "write erase". When you issue that command, do you get a "Erase of nvram: complete " or an error? Are you issuing the "reload" command after a successful erase? Be sure you answer No when it asks "System configuration has been modified. Save? [yes/no]:" as sometimes this seems misleading and some people think they mean to save the reloaded default. They are really warning you that you are about to loose the old configuration and attempting to prevent you from accidently erasing it. So answer "no". After a successful reload of the IOS you should also clear any VLAN information. To do this, issue "delete flash:vlan.dat" and then do another "reload".
Posted on Aug 29, 2007
Fixe_You
  • 1800 Answers
SOURCE: Resetting phones and restoring to full factory default.
okay i will fix the prob but i need model name
and fix ya rate after giving the solution okay??
Posted on Aug 19, 2008
  • 40 Answers
SOURCE: Want to reset to Factory Default
If you don't have a set of restore disks, turn the laptop off and then on and watch the screen carefully. It will usually say something like Press F11 (or some other key) for Restore. Press the stated key while you can still see the message. Then, simply follow the prompts.
In case you have then press F11 on the keyboard, in case the same does not work the
Start > All Programs > HP Backup and Recovery > HP Backup and Recovery Manager. The same file may be hidden (locate the file through) D:\HP_Recovery\MiniNT\System32\start.exe.
Regards,
TechSup1
Posted on May 01, 2009
  • 51 Answers
SOURCE: Convertible top motor has run low on oil. Need to
The motor/tank is usually in the boot/trunk, either under the spare wheel or behind a side panel.
Posted on Nov 13, 2010
  • 104 Answers
SOURCE: Front heater does not work in '04 suburban. Does
Sounds like there is a issue with the front blower motor I would check your fuses first because sometimes the motor jumps in voltage causing the fuse to blow. Check your user manual for location also if that is not it and the motor is getting power it could also be the switch that controls the blower motor.
Posted on Nov 30, 2010
How to hard reset andriod phone when changing password
not sure what p/w you want to chg but a hard reset isn't necessary to do that. If you do it will bring your phone back to factory defaults and you will need to renter/reload everything.
The factory default reset is on the device menu.
This is for my Droid Pro - look for it in ur manual.
Reset
To reset your phone to factory settings and erase all
the data on your phone, touch Menu > Settings
> Privacy > Factory data reset > Reset phone.
Warning: All data on your phone will be deleted.
(Nothing on your memory card is deleted.)
Jul 07, 2014 | Google Android
How to delete old frequencies on bc340crs?
To reset the scanner to factory defaults, turn off the scanner. Then, while
holding down 2, 9, and HOLD, turn on the scanner. All scanner memory
contents are erased.
May 26, 2014 | Uniden BC340CRS Base Scanner
Eristic gaskets
Use factory gaskets aor use FelPro.
Nov 01, 2012 | Nintendo Wii Video Game Consoles & Games
Forgot WEP password -- Where can I find it?
You will either have to call you ISP (Internet Service Provider) and ask them to reset it, or you will have to stick a needle or pen into the reset button on the router to reset it all, the new default password should be the number on the back of the router.
Jun 29, 2011 | AOpen AOR-401M Router (90.18R10.402)
Hi. i want reset my nokia n73, ( memory full)and want delete some data. what are you doing in this prablem? i think that i need one cod.
*7370# is the codeyou should backup any of the data on your phone that you do not wish to delete it will erase everything from the phone memory and reset the phone to factory default settings. Good luck.
Mar 01, 2011 | Health & Beauty
How to format nokia xpress music????? pls help me....
Soft Reset The reset will restore all the phone's settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory, including take off your memory card.
  1. Switch off the phone.
  2. Press GREEN + RED + CAMERA + ON simultaneously until you see the "Select Country" option.
Note:
  1. The default password is 12345. You need to press and hold the key until the number appear.
  2. Please do not confuse "revert to factory settings" with soft reset. "Revert to factory settings" can be achieved from Menu > Settings > Phone > Phone mgmt. > Factory settings or *#7870# code, and will only restore the phone to its factory setting without deleting data.
If this answer helpful RATE please
Jan 29, 2011 | Nokia 5800 XpressMusic Smartphone
I locked my tv and can't remember my password
try to initialize the tv is like reset to factory mode, by pressing menu and input for 30 seconds until you see the word *initialize* on screen and press ok aor enter until this process is done.
Dec 18, 2010 | Mitsubishi VS-6043 60" Rear Projection...
How do I delete program times for the filter pump on the Aqualink rs8 panel?
These are great systems: Go into "MENU" (MENU BUTTON) Scroll down until you see "MENU/HELP" Scroll down to "PROGRAMS" - HIT "SELECT" when you find "PROGRAMS" It will say "PROGRAM 1 of 1" that is what you want - Hit enter - This will tell you what time the program is set to run
If there is more than one program, You will see "PROGRAM 1 of 2" or however many programs you have programmed.
If you need to delete a program, go to the program you are looking to delete, it will ask you if you wish to delete the program and you will use the up and down arrow on the panel.
It is really that simpe!
For deletion of all programs (factory default). There is a SMALL reset button. The lights will go out and then light up. Will light up to the left and then to the right. Resetting this will erase all run times back to factory default. You will not loose your programs (memory of knowing what system it is) it just resets the times to factory default (1200 Military times). ***IF YOU HAVE A COMPLICATED PLUMBING SYSTEM WITH SEVERAL RUN TIMES - DO NOT DO THIS!**
If you are looking to just erase additional run times and only need the one run time (for circulation) this might be the better option to resetting and erase all run times and reset back to a basic 1 of 1 run time.
Dec 07, 2010 | Jandy Pool & Spa
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
