Question about Bush 5693D 24" TV
Thin blue horizontal line - Bush 5693D 24" TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Thin blue horizontal line klv-32ex300 sony lcd problem
Is that the only thing on the screen and no picture? Or does the pic play but the blue line is there along with the picture?
Aug 12, 2012 | Sony Televison & Video
My tv sony kv-pg21n70 has horizontal white thin line about 2 inches and blue ,green ,red thin line under it
Go to this blog. Type this blog address to the address bar of your borowser and, press Enter.
electronicshelponline(dot)blogspot[dot]in
Insert Dots in proper place.
Apr 07, 2012 | Televison & Video
Tv powers up, but just a thin blue strip on the screen??
which way ?
horizontal line suggests vertical amp failure - dry joints, etc.
vertical line is horizontal scan circuit failure - dry joints, component failure - don't run this too long or it will get expensive
Aug 10, 2010 | Televison & Video
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Bush 5693D 24" TV Logo
12 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
