Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Doesn't want to start or idle but will run at 2,000 rpm
    Master:
  • 416 Answers
A partially shorted fuel injector can cause that
Posted on Mar 26, 2015
At idle 2005 4 litre mustang shows 50 psi at 75 degrees, when at normal temp pressure drops to 15,20 at idle. At 2,000 rpm shows 40 psi. This sounds low to me, is this normal?
That sounds normal. There would be specifications for it that you should check, but that sounds pretty normal. The specs probably show a pressure for idle at normal operating temperature, and another figure at a specified engine rpm. Or it may just have one spec at a certain rpm.
Dec 28, 2016 | 2005 Ford Mustang
How to check my voltage regulator in 1989 Honda Civic
put a multimeter across the battery terminals and start the car
at idle it should read 12 volts and when at 2000 rpms it should read 14.5 to 14.8 volts at higher rpms it should still read those volts
if it goes higher then it is suspect
make sure the multimeter is set on dc volts setting
Jul 01, 2015 | Honda Cars & Trucks
Oil pressure is 32 while idling and goes up when RPM INCREASES
Hi Anonymous, normal oil pressure is 32-38 with engine hot and running at 2,000 RPM. If you are getting erratic readings you could have a bad sending unit or gauge. Good luck
Apr 19, 2014 | Harley Davidson FLHTCUI Electra Glide...
Rpm is always at 2
Idle rpms should be between 1200 and 1300. 2,000 is to high. Your bike will run hotter when idling and also use more fuel when not needed.
Mar 20, 2013 | Honda VT 1100 C Motorcycles
Katana carb diagnostics
Hi, Anonymous and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Idle problem with my GSX 600F Suzuki GSX Motorcycle Forums Gixxer com
Throttle position sensor fix GSXR 750
Suzuki 85 GSX R750 Service Repair Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Apr 18, 2017 | 2001 Suzuki GSX 600 F (Katana)
2005 Katana....Idle (warm) slowly goes from 1,100 to 2,000 rpm
There is an air leak letting outside air into the fuel/air mix. This leans the mix and causes the problem you describe. The diagram below shows the likely carb air leak areas; "O" ring seal dried out, clamp seal bad due to loose clamp or hardened manifold rubber, rubber manifold dried out / cracked, the vacuum cap is loose. Other sources are a loose spark plug, bad valves and leaking head gasket.
Can I get a “very helpful” rating on this answer?
Aug 29, 2009 | 1999 Suzuki GSX 600 F (Katana)
Idle problem when warmed up
Hi there!
On the carburetor, there is an idle knob. Make sure it is not set too high. This is normal during a cold start so make sure to adjust the idle knob back at 1,100 RPM after your engine is warmed up.
Also, make sure the choke system is clean and is free. Throttle cable should have an allowance of just about .8cm.
The engine idle may also be controlled with the thermostat connected to the grill fan. it will normally idle up to about 2,000 rpm when it senses that the engine is too hot but not 4,000.00 make sure this system is working well.
let me know if this helps
-levibit
Mar 29, 2009 | 1999 Suzuki GSX-R 600
2000 v6 5 spd nissan xterra idles high when in gear and rolling .
From the service manual:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
NGEC0549
PREPARATION
NGEC0549S01
1) Make sure that the following parts are in good order.
I Battery
I Ignition system
I Engine oil and coolant levels
I Fuses
I ECM harness connector
I Vacuum hoses
I Air intake system
(Oil filler cap, oil level gauge, etc.)
I Fuel pressure
I Engine compression
I EGR valve operation (If so equipped)
I Throttle valve
I Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
SEF976U
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
SEF977U
4. Perform diagnostic test mode II (Self-diagnostic results). Refer to EC-644.
SEF217U
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
BASIC SERVICE PROCEDURE VG33E
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment (Cont’d)
EC-616
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
SEF978U
3. Turn off engine and disconnect throttle position sensor harness connector.
SEF975R
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
SEF371S
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
GI
MA
EM
LC
FE
CL
MT
AT
TF
PD
AX
SU
BR
ST
RS
BT
HA
SC
EL
IDX
EC-617
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
SEF972R
' GO TO 2.
4 CHECK BASE IDLE SPEED
With CONSULT-II
1. Read idle speed in “DATA MONITOR” mode with CONSULT-II.
PEF356V
700±50 rpm (in “P” or “N” position)
Without CONSULT-II
1. Check idle speed.
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
Mar 25, 2009 | 2000 Nissan Xterra
Xterra repair
Since this is an intermittent problem, first try to determine if the problem arises due to one of these many intermittent problems:
* Vehicle vibration
* Heat sensitive
* Freezing
* Water intrusion
* Electrical load
* Cold or hot start up
If you can't isolate the cause of the intermittent problem, you can try adjusting the Idle Speed/Ignition Timing/Idle Mixture Ratio:
PREPARATION
* Battery
* Ignition system
* Engine oil and coolant levels
* Fuses
* ECM harness connector
* Vacuum hoses
* Air intake system
* (Oil filler cap, oil level gauge, etc.)
* Fuel pressure
* Engine compression
* EGR valve operation (If so equipped)
* Throttle valve
* Evaporative emission system
INSPECTION PROCEDURE
1 INSPECTION START
1. Visually check the following:
I Air cleaner clogging
I Hoses and ducts for leaks
I Electrical connectors
I Gasket
I Throttle valve and throttle position sensor operation
2. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
Ensure engine stays below 1,000 rpm.
OK or NG
OK ' GO TO 2.
2. GO TO 2.
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
' GO TO 2.
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
5 ADJUST BASE IDLE SPEED
1. Rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run engine at idle speed.
2. Adjust idle speed by turning idle speed adjusting screw.
' GO TO 6.
6 CHECK TARGET IDLE SPEED
1. Turn off engine and connect throttle position sensor harness connector.
2. Start and rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run at idle speed.
3. Check idle speed.
750±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 9.
NG ' GO TO 7.
7 DETECT MALFUNCTIONING PART
Check the following.
1. Check IACV-AAC valve and replace if necessary.
2. Check IACV-AAC valve harness and repair if necessary.
3. Check ECM function by substituting another known good ECM.
(ECM may be the cause of a problem, but this is rarely the case.)
' GO TO 9.
9 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
2. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
3. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 12.
NG (MIL does not blink.) ' GO TO 17.
NG (MIL blinks less than 5 times.)
' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
10 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
1. Warm engine to normal operating temperature.
2. Run engine at approx. 2000 rpm for approx. 2 minutes under no-load.
3. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
4. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 13.
NG ' GO TO 11.
11 DETECT MALFUNCTIONING PART
1. Check fuel pressure regulator.
2. Check mass air flow sensor and its circuit.
3. Check injector and its circuit.
Clean or replace if necessary.
4. Check engine coolant temperature sensor and its circuit.
5. Check ECM function by substituting another known good ECM.
' GO TO 2.
13 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
1. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
2. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' INSPECTION END
NG (MIL does not blink.) ' GO TO 16.
' 1. Replace front heated oxygen sensor RH.
2. GO TO 14.
14 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
3. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
OK or NG
OK ' INSPECTION END
NG ' GO TO 15.
15 DETECT MALFUNCTIONING PART
3. Check injector and its circuit. Clean or replace if necessary.
' GO TO 2.
16 CHECK FRONT HEATED OXYGEN SENSOR RH HARNESS
1. Turn off engine and disconnect battery ground cable.
2. Disconnect ECM harness connector.
3. Disconnect front heated oxygen sensor RH harness connector.
4. Check harness continuity between ECM terminal 50 and front heated oxygen sensor RH harness connector.
Continuity should exist.
OK or NG
OK ' 1. Connect ECM harness connector.
2. GO TO 18.
NG ' 1. Repair or replace harness.
2. GO TO 9.
17 CHECK FRONT HEATED OXYGEN SENSOR LH HARNESS
3. Disconnect front heated oxygen sensor LH harness connector.
4. Check harness continuity between ECM terminal 51 and front heated oxygen sensor LH harness connector.
OK or NG
2. GO TO 18.
2. GO TO 9.
18 PREPARATION FOR “CO” % CHECK
1. Disconnect engine coolant temperature sensor harness connector.
2. Connect a resistor (4.4 kW) between terminals of engine coolant temperature sensor harness connector.
' GO TO 19.
19 CHECK “CO” %
1. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
3. Check “CO” %.
Idle CO: 1.5 - 9%
After checking CO%,
a. Disconnect the resistor from terminals of engine coolant temperature sensor.
b. Connect engine coolant temperature sensor harness connector to engine coolant temperature sensor.
OK or NG
OK ' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
NG ' GO TO 20.
20 DETECT MALFUNCTIONING PART
1. Connect front heated oxygen sensor harness connectors to front heated oxygen sensors.
2. Check fuel pressure regulator.
3. Check mass air flow sensor and its circuit.
4. Check injector and its circuit.
5. Check engine coolant temperature sensor and its circuit.
6. Check ECM function by substituting another known good ECM.
' GO TO 2.
Aug 17, 2008 | 2000 Nissan Xterra
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
