Question about Jensen Power 900.1 Power Series Class Ab Monoblock Power Car Amplifier/amp
Overheating overheats as its used to the point it kicks the amp and subs off until it cools down enough to come back on its wired to 2 10 inch rockwell frostgate subs duel voice coils wired at 2 ohms each
3 Suggested Answers
Duncan
  • 218 Answers
SOURCE: Car Audio System Drwing too much power with 2 different Amps
A dual voice coil speaker can be wired to be a 2 ohm speaker or an 8 ohm speaker depending on whether you wire it in series (8 ohm) or parallel (2 ohm). When you bridge your amp then the two channels will share the load from your speaker. If the speaker is wired as 8 ohm then each channel of the amp is driving a 4 ohm load which is fine. If you are bridged into a 2 ohm speaker then each channel will be driving a 1 ohm load, which is a very very heavy load. Is your amp designed to drive a 1 ohm load? If not then that would explain why you are having a problem.
Posted on Sep 14, 2007
jcameo7270
  • 675 Answers
SOURCE: I got these subs given to me brand new from my dad
Ok..If each coil is say 4 ohms and you wire them in parallel you will obtain 2 ohms...in series you will obtain 8 ohms...remember..series resistors add together and parallel resistors(of the same value) divide...so if you were to wire all 4 voice coils in parallel, then you would obtain 1 ohm...or, if you were to series all 4 voice coils then you would obtain 16 ohms...a lot of amps are not stable down to two ohms..the way we did it old school was to parallel each speakers voice coils to obtain 2 ohms..and then we would series the 2 speakers in the box to obtain the 4 ohm load needed by the amp
Posted on Jan 07, 2011
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
When idling my jeep overheats. The cooling fan is running and it speeds up when temperature goes up. The temperature gets close to 260 degrees and the engine tries to stall. when I start moving it cools...
At idling speed an engine does build up a lot of heat and the cooling fan will kick in. In slow moving traffic or traffic jams the temperature gauge can touch the red - particularly on hot days. The reason it cools down when you start moving is because of the air flow through the radiator.
Presumably there are no leaks from the cooling system otherwise you would have mentioned it. In normal circumstances the fan will not be running as you are driving at speed, as the air-flow through the radiator is sufficient to cool things. The fan only kicks in to get rid of excess heat - and this usually occurs at idling speed or after you have parked the car.
If the fan is running all the time as you drive, this points to either a fault in the fan switch, or the car is running too hot. presumably in normal driving the fan isn't running and the temperature gauge reads normal?
It is common - in stationary traffic many cars overheat (particularly big engined models) try to stall and 'cut out'. Restarting can be difficult until the engine cools down.
Is your car overheating in normal driving conditions or just at idle speed? Overheating in normal driving conditions can be caused by things like a failing water pump, blocked radiator, collapsed hose, faulty thermostat or, in the worst case scenario, cylinder head problems.
Overheating at idling speed is 'common'. Check your coolant level. If your car isn't using/losing coolant then there probably is no major problem. You can flush out the cooling system and refill with new coolant - and also check your radiator. Are the cooling fins crumbling with age? Or maybe they're partly clogged with insects and debris from the road? A blast with a hosepipe wil sort that out ..
The question is how much does your car overheat in normal driving? If it doesn't .. it appears as though you have nothing to worry about as such. Most cars have 2 speed fans... the 2nd faster stage kicks in at some point dependant on engine temperature. Perfectly normal.
Aug 14, 2010 | 2003 Jeep Grand Cherokee
Amp overheats and wont output high volume
It sound like you have a fault on one of the speakers, try disconnecting the speakers and see if still overheats.
Nov 21, 2009 | Car Audio & Video
2000 Plymouth Voyager Overheating
cOOLING fAN tURNS ON @ 210-230 dEG. tEMP sENSOR bAD & OR fAN relay cAN cAUSE THIS pROBLEM
Jun 02, 2009 | 1998 Plymouth Voyager
Overheating & won't start. Oil & coolant OK.
Sounds like your thermostat is stuck in the closed position. I'd replace the thermostat and flush & refill the coolant.
May 07, 2009 | 1995 Ford Explorer
Sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Kicker SX900.2 keeps overheating. Please help!!! = )
sorry your problem is the soft you moust go to the service center
Aug 16, 2007 | Kicker ZR600 Car Audio Amplifier
Amp Will Not Stop Overheating
You say you have 2 p312d2 subs. Ok so the d2 stands for dual 2homs (2 X 2homs voice coils per sub) , conecting in parallel the 2 voice coils of only one sub will create 1hom load to the amp, and if your amp is 2homs stable per chanel that means you are lowering too much your homs causing the overhwating to it.
Sep 25, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Amp overheating
You could just have a simple idling bias or dc balance alighnment thats needs attention. Always take care of the smaller problems before they grow as this problem could grow to where it pops your outputs , your speakers or the drivers. Try this before sending it in. 480-967-3565 Good Luck
Jun 09, 2006 | Rockford Fosgate Power 1000BD Car Audio...
Jensen Power 900.1 Power Series Class Ab Monoblock Power Car Amplifier/amp Logo
27 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
