Question about GE Refrigerators
Replace funner ice dispenser on GE refrigerator PSS25NGMD CC
Paddle broke; need to replace with new one
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
cactus bob
  • 267 Answers
SOURCE: Need your opinion on buying a new GE Profile refrigerator.
no dont do it GE is just bad news . if you must by ge make suer you buy the extended warr .and keep it current YOU WILL NEED IT ! ....... what one should buy? it does not matter , there all the same refrig inside ,just just STYLE you pick DONT FORGET EXTENDED SERVICE PLAN !
Posted on Jan 16, 2009
  • 77 Answers
SOURCE: remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Posted on Apr 24, 2009
I have a GE refrigerator water comes out but it's not making ice. Bought a new filter.model number GAL25JFXN LB
there are several possible causes for your symptom: failed water valve, failed dispenser microswitch, or the line has frozen solid where it runs close to the freezer interior approximately 4 inches from where it dispenses. push a long plastic zip-tie up the water line above the water dispenser paddle. if it stops against an ice blockage you will need the water line heater kit from GE.part#WR49X10173. If there is no blockage, remove the rear service panel and follow your supply line to the water valve...have a helper push the dispenser paddle while you feel the valve body- if there is no hum or vibration you may need a new valve#WR57X10032. things get more complicated if neither of those tips help, time to call a Tech!
Apr 08, 2016 | GE Refrigerators
When the paddle is released water /ice keep coming out until the freezer door is opened GE GSL25JFPBS Side by Side Refrigerator
the return spring on the paddle has probably broken keeping the micro switch on and dispensing,or the dispenser board is defective causing this
Apr 07, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a GE GSS25TSRD SS refrigerator. The cubed ice dispenses properly but crushed ice is not working. Any thoughts?
Remove the ice bin and move the metal bar that sticks out the back of it up and down. It should move easily and spring back. If ok look at the white plastic square piece below auger where the metal bar inserts into when bin is in place. You should be able to lift that up and down easily. If its stuck it probably needs replacing. If thats ok then press the freezer door switch in while pressing the dispenser paddle for cube ice. The white plastic part should move up the down when paddle is released. If no movement the solenoid is bad for it or its not getting voltage.
Sep 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I replaced the water paddle now neith ice or water work
either a wire/block is not plugged in good or the micro swicth is not being activated. possibly the cup/glass cradle not in correctly. Recheck instilation
Mar 02, 2010 | Kenmore Refrigerators
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice Dispenser
If you access the ice container and remove any partially melted ice - maybe the ice maker will work. We had a similar problem. We opened the ice reservoir and discovered ice cubes that had partially melted together. Once we removed those, the ice maker and water dispenser returned to normal. Now we check every so often.
Apr 04, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
