Question about Stihl Garden
Weed eater starts ok but stalls in the upright position or trimming position
  • Stihl Master
  • 1,807 Answers
Could be drawing in air from a damaged fuel line.?
Posted on Feb 27, 2016
  • 53 Answers
SOURCE: weed eater bogs down
Under what conditions does it bog down? When it just idles? Cold or hot? When you give it gas? When you try to cut?
Posted on May 11, 2010
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
SOURCE: weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Posted on Jul 27, 2010
  • 36 Answers
SOURCE: weed eater bogs down when i try to give it full
have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Posted on Sep 22, 2010
SOURCE: Tryingto replace my troy built weed eater's head
clean grass off between shaft and the top of the head. hold weed eater still and turn the head, looking between the shaft and the top of the head. There will be what looks like a hole. Place something there that will keep the shaft from turning, then twist the head off.
Posted on May 25, 2011
Weed eater runs fine till I tilt it down to start trimming then it dies??
Check the gas line that is in the fuel tank . It has a filter on it and if its not down at the bottom of the tank where it should be then its not getting the gas it needs. If you tip it the gas may be too low for the hose to pick up. The hose needs to be on the bottom.
Jul 14, 2016 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do I remove the spoolhead so as to afix the pivotrim head
    I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
    Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
    Enjoy! :-D
    Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
    Weed eater starts but won't stay running
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    WEED EATER STRING
    you have the string in backwards, or the gear is not ingauged.
    Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Weed eater shut down once I began to trim
    Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
    Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
    If you need further assistance, just let me know.
    Jim
    Jul 01, 2009 | Ryobi Garden
    Poulan Weed Eater Trim Line Constantly Jams
    Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
    Jim
    Jun 13, 2009 | Poulan Garden
    31cc Ryobi weed eater engine will start, then stall shortly after
    you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
    May 24, 2009 | Black & Decker 19" Electric Lawnhog...
    Garden Logo
    24 people viewed this question
    Top Stihl Garden Experts
    Joseph Mueller
    Joseph Mueller
    brotherscott
    Level 1 Expert
    ray gallant
    Are you a Stihl Garden Expert? Answer questions, earn points and help others
