Question about Htmarket Countertop Bag in Box Butter Dispenser
Cretors countertop butter dispenser - Htmarket Countertop Bag in Box Butter Dispenser
Countertop ice maker stopped making ice
No point wondering why if there still is warranty....take it back and get another one.
Jan 20, 2017 | Refrigerators
Kettle motor is out need a replacement motor
The motor for a Gold Rush 6oz popper is #2429-A. It is available from any Cretors Distributor with a service dept. I don't think you can buy Cretors parts online anywhere. http://www.cretors.com/dealers.asp?i=16
Mar 27, 2014 | Cretors Goldrush Popcorn Maker
Suction does not work
I had the same issue. What I discovered is that when the pump removes the butter it creates a vacume inside the butter vessel. the pump has a hard time overcomming the created vacume. I have drilled an 1/8" hole in the top to allow air to replace the removed butter.
Feb 09, 2014 | Paragon 2018 Pro Style Butter Warmer
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
Manual for cretors 32 oz popper
Contact your nearest Service Centre for Cretor's products. See the directory here: http://www.cretors.com/dealers.asp?i=16
You must take the Cretor's training course to have access to their manuals and technical information. Your Service centre should eb able to provide a copy of the manual for your machine.
Thank you for using FixYa!
Oct 22, 2011 | Cretors Goldrush Popcorn Maker
I need two doors for our Cretors Goldrush Popcorne Machine Serial # 99021281
Try calling their tech support at: 773-433-7450 or try finding a local dealer at: http://www.cretors.com/dealers.asp Have your serial number ready.
Try finding a local dealer at: http://www.cretors.com/dealers.asp
Jan 19, 2011 | Cretors Goldrush Popcorn Maker
Door dispenser will not dispense the ice.
you and many others have this problem . ( tip remove bin and rinse out with warm water dry it well and the door area also then the majic ... spray the dispenser with ( pam ) without the butter . clean and slick . this should help . mm
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Cretor Gr6 popcorn machine overheated noe it does
Try calling their tech support at: 773-433-7450 or Try finding a local dealer at:
Apr 12, 2010 | Cretors Goldrush Popcorn Maker
Doors for Cretors T-2000
Nov 07, 2009 | Cretors Antique Goldrush Popcorn Maker
Htmarket Countertop Bag in Box Butter Dispenser Logo
Top Htmarket Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Htmarket Kitchen Appliances - Other Expert? Answer questions, earn points and help others
