Question about Konica Minolta BizHub C650 Copier
Konica 8050 error sc 2906 - Konica Minolta BizHub C650 Copier
  • Konica Minolta Master
  • 6,161 Answers
This going to take a while, open both front doors do not pull out the lower section your going to pull out the upper middle section. then from the right side (WHAT EVER YOU DO NOT LEAN / HOLD ANY ONE OF THOSE FOUR SHAFTS!!!!!!!!!!!!!!! THAT WILL CAUSE MAJOR TROUBLE!!!!!!!!!!! ) Now reach in and you will see a small assy. which is across from the transfer belt on the other side of the unit you just pulled out. On the assy. are three sensors each covered bye a metal cover with a dry rag ensure no static electric can destroy the sensors. clean all three, be careful each has a small spring do not let them fall inside the machine. If you want to or have to remove that assy. there are two screws and once connector all the way in the back (DO NOT LEAN ON THOSE SHAFTS!!!!!!!!!!!) dont let the screws drop!. Once done remove the transfer belt, and clean the transfer belt cleaning blade system, then run gamma, and color checks in 36 mode. GOT IT! Better have a tech come out.
Posted on Jan 10, 2016
I need a technician in metro atlanta who has expierence with konica minolta c500 or 8050
contact the manufacturer we have no idea who does that service for them anywhere
Nov 17, 2015 | Konica Minolta Bizhub Pro C500
Konica bizhub press c6000 AA errors
What is the error code C-XXXX or SC-XXXX or Jxx-xx what was it doing when it happened?
Jun 05, 2014 | Konica Minolta Bizhub Press C6000 Copier
Sc 35 -02
Fusing unit upper roller thermistoe defective.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON.Keep pressed the Utility key when appear Trouble reset message on screen.Reset and turn OFF the copier.Wait 1 minute and turn ON.
Dec 07, 2013 | Konica Minolta Konica Bizhub Pro 920 Toner...
Error code sc 49-04 for konica 1050 copier
Aug 27, 2012 | Office Equipment & Supplies
I have problem witm color copier konica minlta 8050 with error sc28-02
Check the yellow drum charge corona to get that open the front of the machine unscrew the front section then pull out he charge corona for yellow do not have open the unit to expose belt and drum. ensure they all are seated properly
Feb 02, 2011 | Konica Office Equipment & Supplies
Which drop side models are on the recall list?
The following model #'s are involved in at least one of 6 different recalls issued for Simplicity brand cribs.
  • Recall due to chipping paint: 8740KCS SC/Serial Nos. 2803 SC to 1605 SC
  • Recall due to mattress support issues: 8740KCS SC/Serial Nos. 2803 SC to 1605 SC
  • Recalls due to drop-side issues:
  • 8910, 8050/Serial Nos. 3005Y to 0806 HY
  • 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, 8996
  • 8620, 8745, 8748, 8755, 8756, 8778, 8810, 8994
  • 8050, 8325, 8620, 8745, 8748, 8755, 8756, 8765, 8778, 8810, 8994, 8995, 8996
You can view the full recall details via the following link:
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml09/09260list.html
Jan 09, 2010 | Graco Lajobi Kendal Convertible Crib
Tech support
F45-20 Color registration correction
results in abnormality.
Printer control board (PRCB)
Color registration sensor /F (PS8)
Color registration sensor /R (PS9)
May 16, 2008 | Office Equipment & Supplies
Konica Minolta BizHub C650 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
