Question about Razor Pocket Mod-bistro Retro Scooter
Battery charge switch on but don't run - Razor Pocket Mod-bistro Retro Scooter
I get my battery charged the car will run but act as iun
Check the acid level or check whether the battery terminals are connected correctly.
Aug 07, 2012 | 2002 Saturn L-Series
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Car stopped working at 5 mph in parking lot with battery light on and after cranking 2 or three times, there was no change. I have 110K miles on car... what do you think? Passat GLX 2001
your car appears to have been running off the battery instead of the alternator, the only thing the battery really does is start the car, once running the alternator runs it, check and clean all the battery connections, if you have a tester , set the voltage to DC volts and see what the voltage is, you should have 12.4 as a minimum, if you don't, Once the cables and posts have been cleaned, try jumping the car again, once its running, check the voltage again on the battery posts, you should have a minimum of 13.5 volts showing, this will tell you if your alternator is charging the battery,, sometimes dirty cables don't allow the charge to actually reach the battery, if you have that voltage,, run the car for a while so the battery charges,
Jul 06, 2011 | Volkswagen Passat Cars & Trucks
E100 scooter wont run. Battery fully charged, 24v across terminals. Motor runs fine when connected directly to battery power. On-off power switch, breaker switch, brake unit switch, accelerator all checked...
It is possible the new controller is defective, however just because the voltage is showing 24v it may not be outputting the correct amount of amps so don not rule out batteries before checking the following:
To test a battery you need to 'load test' so (with help) connect the battery directly to the motor when weight is on the scooter to see if it will still pull.
Please also remember that you do have to push the e100 to 3mph before starting (many users do not know or forget this step)
Jul 04, 2011 | Razor E100 Electric Scooter
I have the same problem as jeffwater. seldom use the car in the winter and battery is dead if I don't run the car every two weeks or so. I don't see a switch on the trunk light. is it possible...
Hi, Car batteries lose their power over time if not used or charged. If you store your car in winter, take the battery out and give it a slow charge every month. (just like you do with a motorcycle battery). Or, start the motor and let it run 15-20 minutes every couple weeks. I would recommend doing that anyway to keep the engine oil from draining completely out of your bearings and possibly siezing up motor upon startup a few months later or bearing/engine damage due to excess wear on dry bearings. Thats the nature of the beast, there is no cure for it. Mike
Jun 18, 2011 | 2004 Mazda MX-5 Miata
If the battery is fully charged when i plug the charger stopped charging or not in Lenovo z560 ?
Welcome to FixYa
When the battery is fully charged and you still have the ac adapter plugged in then the battery would no longer be charged. The computer would then be running on ac adapter power.
hope this helps
Jun 04, 2011 | Lenovo IdeaPad Z560 Notebook
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
My phone switch on and white display and restart it why this problem solution
If you see white screen for a long time and after that your mobile get switch off then I think this is a battery problem. This problem also occurred when your mobile don't have charge and you try to switch on your mobile phone. make sure your mobile phone is properly charged. If you charged your mobile phone regularly and you still not able to switch on your mobile, then try to place new battery in your mobile and then try to start your mobile phone. hope it works for you. Or there may be chance of virus, but I'm not sure. Better you check for it. if your mobile don't support any antivirus then try to scan your mobile with connecting pc. You can connect your mobile phone to pc. And then scan your mobile for virus. If you found any virus then remove it from your mobile. If not found, then definitely its not a virus.Then it is the problem of battery. thanks
May 15, 2011 | Computers & Internet
USING PERKO SWITCH HOW DO I POSITION SWITCH USING 120 VOLT AC CHARGER USING 2 MARINE BATTERIES AND WHAT TERMINALS ON BATTERIES DO I HOOK UP ALLIGATOR CHARGING CLIPS? THANK YOU DON
Hi Don!
If you wish to charge one battery at a time, the switch should be set to "off". Charger clips will connected to the batt you wish to charge hot-to-hot and cold-to-cold. If you want to charge both batts at once (not really recommended) switch set to "all".
Hope this helps.
Mar 26, 2011 | Perko Battery Selector Switches Ignition...
Battery not holding a charge
Hi
Normally all circuits should be dead when you switch off the ignition.
Only usual live one, is the radiator electric fan.
You should hear this running after you switch off, for only a short while, if you listen you can eliminate this.
Perhaps glove box, or trunk lights are sticking on ? but normally you only get them if side lamps are on, but still worth checking !
You will have to try disconnecting the battery over a weekend, if it is flat on Monday, it must be the battery.
Good Luck
P.S. Don´t forget to give me a rating please !
John.
Jan 20, 2009 | 1991 Toyota Camry
Razor Pocket Mod-bistro Retro Scooter Logo
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
