Question about Dryers
970-c84102, squeaking Very loud squeaky noise
  • 184 Answers
SOURCE: squeaky dryer
IF THE LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THERE ARE TWO SCREWS UNDER THE LINT FILTER THAT NEED TO BE REMOVED. REMOVE THE LINT FILTER ALSO.
PULL FORWARD AND UP ON THE DRYER TOP( NOT JUST THE CONSOLE) AND DISENGAGE THE TOP FROM THE FRONT. THERE ARE HINGES ON THE BACK OF THE TOP JUST PIVOT IT UP OUT OF THE WAY. NEXT, THERE ARE TWO 5/16 HEX HEAD SCREWS INSIDE THE DRYER NEAR THE TOP IN EACH CORNER THAT HOLD THE FRONT TO THE SIDES. REMOVE THEM AND THE FRONT WILL PULL FORWARD. IT IS HINGED AT THE BOTTOM. LIFT IT OFF THE HINGES AND SET IT ASIDE. YOU CAN NOW UNDO THE BELT FROM THE MOTOR AND IDLER AND USE IT AS A HANDLE TO LIFT THE DRUM OUT OF THE CABINET.
THE DRUM SUPPORT ROLLERS ARE LOCATED AT THE REAR OF THE MACHINE AND CAN BE REPLACED AS A SET. THE NUMBER IS 349241T FOR THE TWO PACK.
CLEAN THE SHAFT WITH SANDPAPER BEFORE INSTALLING THE NEW ROLLERS. THEY ARE HELD ON WITH TWO TRIANGULAR CLIPS. JUST CUT OR BREAK THE OLD ONES. THE NEW ROLLERS COME WITH NEW RETAINING CLIPS.
AFTER REPLACEMENT, REASSEMBLE IN REVERSE ORDER.
Posted on Apr 08, 2008
  • 210 Answers
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
Posted on Jun 03, 2008
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
  • 132 Answers
SOURCE: dryer making loud squeaking noise
Replace all the drum rollers.
Posted on Mar 26, 2009
  • 479 Answers
SOURCE: Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Posted on Aug 11, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Loud squeaking and rattling when you accelerate after a stop
Is the underside rusty? If so, take it to a qualified welding and autobody repair shop to have new metal welded on.
Your symptoms sound like the engine or transmission mounts may have deteriorated.
Jul 04, 2010 | 2003 Chevrolet Blazer
Loud squeaky noise from front tires when turning and somtimes whe
Hi my name is Tom and I can help you.
Driving with your emergency brake on is only going to affect your rear brakes. There is a cable running from the emergency brake lever to your rear brakes.
You did not say how long you drove with the emergency brake on, but even a short distance and you forced the front brakes to do the work of stopping the car. This causes overuse which translates to heat. When the brakes over heat they "fade" and do not stop the car effectively.
In addition the heavy load of doing all the stopping causes the brakes not to realign. Therefore, when you go around corners the brakes pads will rub against the rotors.
I would suggest you get the brakes looked at or look at them yourself. I can help you do the job but I would need to talk to you directly. Let me know what I can do to help.
TomE
Jun 29, 2010 | 1995 Ford Escort
Loud squeaky rear wiper on a 2000 odyssey.
Before you go through the time and hassle of removing the motor itself, spray some WD-40 or something similar on the shaft that goes to the motor...could be the weather seal is dried and squeaking.
Dec 13, 2009 | 1999 Honda Odyssey
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Unit making loud squeaky noise
http://www.youtube.com/watch?v=7n5tywSdWKs
This is a cool video with link to applience parts for help and answers
Feb 02, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Dryers Logo
23 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
