Question about Audiovox Science & Laboratory
Set clock audiovox kcd3180
Operating instructions
Where can I get an instruction manual for Audiovox dual alarm clock radio for iPod CR8030iES?
search it in the internet google or yahoo... just type instruction manual for Audiovox dual alarm clock radio for iPod CR8030iES?...
Apr 25, 2011 | Audio Players & Recorders
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
No instructions for Jensen dual alarm clock radio with dock
Downloads for several Jensen clock radios available.
What model ?
Your model could be listed on the next page:
http://www.spectraintl.com/downloads.html
spec sheet
manual
Main link for support on Jensen products:
http://www2.audiovox.com/corporate/corp_jensen.do
Oct 19, 2009 | Jensen Audio Players & Recorders
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Have Pioneer DEH 1900MP CD receiver. Do not know how to set time. Have no amnual. Also information on the remote control
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Operating this unit
12 En
Aug 05, 2008 | Car Audio & Video
Set the clock
This is the original manual. Put just hold down the clock/track button until it beeps.
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/ICF-CD831-_E
Jun 02, 2008 | Sony PSYC ICF-CD831 Clock Radio
Audiovox Digital Answering System Operating Steps
i found this after searching the web for a long, long time.
http://safemanuals.com/user-guide-instructions-owner-manual/AUDIOVOX/AXT847-_E
Apr 01, 2008 | GE 29875GE Digital Answering Machine
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Science & Laboratory Logo
91 people viewed this question
Top Audiovox Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Audiovox Science and Laboratory Expert? Answer questions, earn points and help others
