I have a washer model# wtw6400sw1 after I run my cycle I noticed the clothes are wet a little bit After each load I have to run the drain and spin cycle to get all the water out Please help me figure out the problem
    Problem Solver:
  • 12 Answers
Don't put so many clothes in, if it cant find a balance it won't reach full spin speed.
Posted on Apr 19, 2014
  • 1294 Answers
SOURCE: clothes are soaking wet after cycle is done
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Feb 02, 2008
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
Posted on Aug 04, 2008
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
  • 19 Answers
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Posted on Jan 25, 2009
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Will not totally spin
Jan 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
Jan 11, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
RAS6233KQ2 TOP LOAD WASHER WILL NO SPIN CLOTHES
Nov 03, 2008 | Roper RAS6233KQ Top Load Washer
Clothes are still water logged after cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
From Repairclinic
Oct 24, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
