Question about Canon F-502 Calculator
Reset canon F-502G - Canon F-502 Calculator
I have a canon F-502G and my number 9, pi, decimal sign and X(OCT) don't work. Please help! I've tried everything and I don't know what to do. Also there is OCT on my screen.
Your problem is that the calculator is in Base N calculator mode (Octal, base 8). only the keys 0 to 7 are active. Change the mode to Decimal (base 10) or reset it completely, and your calculator will come back to life.
Jan 04, 2016 | Canon Office Equipment & Supplies
How to calculate regression analysis
It depends on what your doing, lets just say you want to compare two curves to the same data. First off save the fitted valurs from each model in the worksheet, which you can do by checking the "fits" in the storage dialog. Save the fits for all models you want to compare which I call fit1 and fits 2.
Then you create a scaterplot and display the
Following pairs, original response and predictor data. Fits 1 predictor data fits 2 predictor be sure to check overlaid on the same graph on the multiple graphs dialog. After you create a graph you need to teek it by adding connect lines. Click on the data point on the scatterplotin the menu choose, edit> Add> data display "connect line". This will connect lines to all your datasets, unfortunately you don't want that don't sweat it easy fix to make that go bye bye slowly double click on the connect lines on the original data, which selects the specific connect line, if you do it to fast it will bring up the dialog to edit all connect lines so slowly double click you know like a finger spasm lol. Anyways right click and choose edit connect lines choose custom scroll up and choose none and thats it tour done. Hope this helped
Nov 06, 2014 | Canon F-502G Scientific Calculator 140...
Cannot find the shift key
The shift key is the top Left button (it as no markings on it), to the left of the ENG button
Mar 04, 2014 | Canon F-502 Calculator
How do i get negative numbers on my canon F 502G
Use the (-) key located above the 8 key.
Aug 12, 2011 | Canon F-502 Calculator
I have grover Roto-Grip Locking Rotomatics on my gibson les paul and for the top 3 strings it doesn't seem like the opening is large enough to feed the string through even when the thumb screw is...
They come as a set of 6, with three for the treble and 3 for the bass... MAKE sure you have the correct ones for the bass as they will have three with larger holes to accomodate the larger strings.
Jul 22, 2011 | Grover 502G Roto-Grip Locking Rotomatic...
Connecting prob
can't connect to the internet think i need the driver to Arris-502g modem
Jun 06, 2008 | Computers & Internet
Canon F-502 Calculator Logo
220 people viewed this question
old marine
old marine
