Question about Fellowes 3400701 P-7C Cross-Cut Shredder - Black/Gray
Stopped working during shredding of tooo many sheets sat one time
How do i increase the number of pages that the shredder will shred at one time?
you can only shred what it will take , trying to force more in will only break it faster .
Oct 16, 2015 | Shredder Office Equipment & Supplies
When i put paper in it to shred it cuts then stops. ihave to physically hold the shred button for it to shred?
sounds like the paper in switch is either worn, or loose. Not much you can do unless you replace the switch. Look in the slot where you would place the paper and see if you see a small lever. If you do, watch it when you place paper in and get the shredder to work.
Does it happen on single sheets or multiple sheets. If just single, try multiple sheets and see if it works better.
good luck
Mar 05, 2015 | Office Equipment & Supplies
Auto off does not work how do I fix this?
Check to see if the feed is clogged up. If it is, clean it out and try to shred. These machines don't last forever, it may be worn out and time to buy a new one.
Sep 14, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Motor stops during shredding
Have you ever oiled the machine???
When does it stop...with just 1 sheet????
Put some shredder oil onto the cutting blades first and see how that helps.
Jan 26, 2011 | Royal 29140X PX100MX Cross-Cut Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Shredding
check door safty switch or is the bag or box full that has a switch also? just a suggestion.
Jun 24, 2008 | Aurora Electronics AS1015CD Cross-Cut...
Shredder stops after about 10 minutes
spray the sheddred wheels with wd40 or any lubricant
Jan 18, 2008 | Aurora Electronics AS1010TX Cross-cut...
Fellowes 3400701 P-7C Cross-Cut Shredder - Black/Gray Logo
41 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
steve morris
steve morris
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
