Question about Logitech Audio Players & Recorders
Logitech jam2 speakers cut out - Logitech Audio Players & Recorders
New Logitech Z200 Speakers cutting out due to on screen information messages
Some more information would be helpful. Does it give you volume then cut out? Might just be cabling, could be drivers. Can't narrow down without slightly more detail than that. As always if it is windows 10 and it's drivers I suggest www.win10hq.com to get in touch with their staff including myself directly as well.
Aug 08, 2016 | Logitech Z200 2.0 Multimedia Speakers...
Can not get my Jam2 wireless speaker to connect to my iPhone 4s
Go into "settings" on your iPhone, and "enable" the Bluetooth interface.
Apr 13, 2014 | Cell Phones
Cant pair hmdx jam plus with my ps3
does anybody kno how i pair my jam2 bluetooth speaker to my ps3,it will find it but when i try to connect ot will ask for a passkey and i dont know it.many thanks
Nov 30, 2013 | Radio Communications
Jam2 speaker will not go into pairing mode so i can pair it with my ipad2
On my Jam2, pushing and holding the play button puts the device into pairing mode. Nothing in the instructions suggests this, but it definitely works. You'll know it's gone into pairing mode when the blue indicator light begins flashing quickly.
Sep 08, 2013 | Radio Communications
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
Logitech z5500 speakers no power
certainly sounds like a fuse problem. First check that the fuses you have used work in another appliance. You should not have to use a fuse from the logitech company but it will be rated for your speakers so would probably be best. If the fuse checks out (both plug and amp) then check the wall socket and the power cable.
Mar 29, 2010 | Logitech Z-5500 5.1 Digital Speaker System...
LOGITECH THX Z560 NO SOUND
Im having the same problem - where is the fuse
Oct 18, 2008 | Logitech Z-560 Computer Speakers
Ups and Downs with Logitech
yeah repair the volume switch, open the speaker carefully and pump out the lead which connected the switch and the board..
Oct 11, 2007 | Logitech Z-340 Computer Speakers
53 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
