Question about Samsung Dryers
Samsung dryer dv361 wont run - Samsung Dryers
Dryer runs for five minutes then stops, so has power. there is no error code, where do I start to find problem?
Usually with no error code its almost always in the board ..My suggestion is try to run it through test mode if it wont run through then replace your main board.The papers for this should be under the top panel tremove it look for some papers usually on the left as you are facing your dryer hope this helps
Mar 02, 2015 | Samsung DV218AEW Electric Dryer
My samsung dryer dv330aew/xaa wont heat up is there a reset switch?
you can check the element with a multi meter for continuity. may also want to check the hi limit thermostat and the cycling thermostat, do u have full voltage at the terminal? sometimes a tripped breaker will give you half voltage say 110 instead of 220 and what u get is enough power to run the dryer motor but not the heat as it takes a full 220 to run heat
Sep 08, 2014 | Samsung DV330AEW Dryer
Dryer wont spin
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Samsung DV328AE Electric Dryer
My dryer wont run
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Samsung DV328AE Electric Dryer
Our samsung DV220AE dryer wont dry (NO HEAT)
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 26, 2010 | Samsung Dryers
Drum wont turn
heatman101
Nov 07, 2010 | Samsung DV330AGB Dryer
Power is on, push start button, light blinks on front but will not run?
may be a reset button on motor:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Samsung 7.3 Cu. Ft. Super Capacity...
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
Dryers Logo
42 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
