Question about Bulova Watches
Collezio watch open the back to replace battery
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
What type of battery needed for a collezio watch
what type of battery does my collezio watch use?
Mar 29, 2013 | Watches
How do I open the back of the watch to replace the battery & what type battery does it take? Thanks Ian Lawes
Usually the back of a watch is sealed with simple screws. Just unscrew them with a jeweler's screw driver and it will open the battery compartment of the watch.
The battery depends on what type of watch you are using. The most common batteries for watches are about less than 3/8 of an inch.
Mar 04, 2011 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    How do you open the back of a raymond weil men's
    I suggest you take it to a watch shop. DIY battery replacement is not as easy as it seems.
    Frequently there are cries for help after a battery has been replaced and the watch no longer works!
    Feb 10, 2010 | Raymond Weil Parsifal W1 watch
    Dead battery, how do I open?
    I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
    Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
    the details of the battery read on top the one currently inside it.
    Jan 30, 2010 | Watches
    Battery replacement - Freestyle shark watch
    Jan 30, 2010 | Freestyle Shark X 75036 Wrist Watch
    Battery....can I get a battery replacement anywhere?
    Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
    Dec 08, 2008 | Skagen Watches
    Concord Impresario battery replacement
    The watch has a tiny screw holding the back of the watch. You must use a very small jeweler's screwdriver to open it carefully and replace the battery.
    Aug 04, 2008 | Watches
    Watches Logo
    22 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
