Question about Sharp LC-50LE442U 50" LED TV 1920x1080, 60 Hz, HDTV
Power on television went off, will not turn back on
Went to turn on tv switched on plug nothing happening no lights on tv power going to
Either your electrical outlet went dead or the power supply in your television went dead. Verify operation of the outlet by plugging a light or other known-working appliance in and, if that is working, unplug your television for a minimum of one hour, plug it back in, and test. If it still does not operate, it will require further service.
May 12, 2015 | Televison & Video
Screen went blank while still on. unplugged power cord and when I plugged it back in the power on light went green. Problem remains
Resolution:
Follow the steps below to troubleshoot this issue.
Verify that the AC power cord is connected securely to a working wall outlet.
Unplug the power cord of the television from the AC outlet.
Let the television remain without power for 1 minute.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
NOTES:
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required.
Make a note of the STANDBY or TIMER flash pattern when referring the television to service.
Aug 13, 2008 | Televison & Video
Why wont my Tv turn back on after the electricity went off?
Did you have your television plugged into an outlet with a surge protector? Does it do anything when trying to turn it on? Might have fried it when power came back on or when elec. went off.
Feb 05, 2015 | Emerson Televison & Video
Why does my flat screen tv turn on and off by it self and the only way to stop it is unplug power cord?
This is an indication that they capacitors in the power supply are going bad.
Jan 20, 2015 | Televison & Video
Jvc lt-z32s2 went dead and makes a static sound at back of unit.
check weather the power cord or component at the power supply board get burned.
Oct 02, 2012 | JVC Televison & Video
Lost house power. Sanyo clt2054 20 turned off now won't turn back on
Check the power supply for fuse, loose connections, etc. What happen when the power went out and came back on, you will usually get higher voltage when it comes back on, you will notice that the light bulb gets very bright when the power comes back on.
Nov 24, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Power light flashing all 3 colors TV will not turn back on
Sounds like the Power supply module. I would take it in to service center ASAP!
May 21, 2009 | LG 32LC7D Television
Sharp LC-50LE442U 50" LED TV 1920x1080, 60 Hz, HDTV Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
