Question about Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator
Fridge out of calibration
Can the on door thermostat be calibrated to reflect accurate temperature inside of the refrigerator system.
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Assistance required
A thermostat would have nothing to do with this problem. Condensation occurs when warm air moves into a cold place. Check door gaskets or any possible way that warm air is getting into the cabinet.
Posted on Nov 07, 2007
  • 15 Answers
SOURCE: temperature going up on refrigerator, inside light going off
Many things can cause this problem...This fridge is computer controlled. there are tests you can run to find out what is going on.....It may help you isolate to the area of the problem...Getting parts could be hard....
Most service personnel can't fix this fridge because it's too complex...
Here a link to the service manual PDF
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Posted on Apr 12, 2010
SOURCE: Samsung Cooltech SL-L551DP fridge Freezer.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care.
Posted on Oct 06, 2010
SOURCE: Fridger temperature selector does not reach the set temperature
CHANGE THE FAN
Posted on Mar 07, 2012
How to calibrate oven?
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
Dec 01, 2016 | Ovens
The humidistat changes with home but reads about 20% low. Can the read out be adjusted to more accurately reflect the actual conditions?
A common problem is dirt. Dirt can affect the thermostat's calibrationand interfere with its operation. For example, if a thermostat is set to heat for 70 degrees is really maintaining a temperature of 73 degrees, the additional energy use can increase your fuel bill by as much as 7 percent.
Google your make and model #manual, the manual will let you knw if it can be calibrated.
Thermostat Temperature Calibration DoItYourself com
Jan 21, 2016 | Heating & Cooling
Calibrate everstar wine cooler display
There is no calibration. You can adjust the thermostat to get the proper temperature. If you cannot maintain proper temperature using the thermostat, several different problems can cause the same symptom. Refrigerant leak, defective thermostat and txv are some problems that can cause lack of maintaining proper temperature.
Jun 09, 2014 | Furniture
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Calibration screw fridge
Try the thermostat on it's lowest setting first. If it doesn't switch off soon enough and gets too cold, you can get different thermostats from your supplier. A bottle fridge thermostat would suit.
Apr 21, 2012 | Whirlpool Refrigerators
Need to know how to calibrate my honeywell RTH221
This thermostat is not field servicable,you cannot calibrate this thermostat.May want to consider moving it closer to return air of equipment, for more accurate sensing of building temperature. Why do you feel that it needs calibrated? Suggest setting another thermometer on top to verify its accuacy.
Nov 24, 2010 | Honeywell Heating & Cooling
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Thermostat calibration?
It's on page 32 of the manual for Thermador's built in convection ovens. 1. turn off the oven 2.touch and hold the start pad and then touch the bake pad 3. 0 (zero) appears in the temp digits. release all pads 4. touch bake and 0 changes in increments. max adjustment is 35 degrees F. 5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
