Question about Beko 324250WN 28" TV
Service Menu - Beko TV
I have TV from Beko Elektronic 7UZ.190-08, and I need to get in service menu. If somebody have manual or direction and code, how I can enter in service menu.
Thank you!
  • boywho Jun 23, 2009
    The Chassis is 22.1, I already downloaded service manual, where is said that in main menu type code 9301 and than service menu will show up. I try but nothing is happend. Has anybody have some advice or solution. tnx
4 Suggested Answers
  • 36 Answers
SOURCE: How to exit service menu
Try this
Use the CLEAR button / long press on the MENU button to toggle between user and svc menu. Press EXIT button to exit svc menu.
Posted on Apr 17, 2009
freetek
  • 5568 Answers
SOURCE: how do you use a beko 32" hd tv as a pc monitor?
Thanks for the detail-
VGA connections are pretty uncomplicated so the only thing that might need setting is the PC's video settings which may be set for higher than the 768 line standard.
The TV may not be sending information to the computer for Plug and Play use but you could try this anyhow:
- Have the TV turned on. the PC off. - If not still connected, connect them. - Turn on your PC.
If the TV set is conforming, it should send a signal packet to the PC with information about itself. You will see early if it had; a Windows dialog box should tell you 'Found new device (or hardware), installing software'
If that or similar did not appear, then after the PC is booted, Open the Control Panel, then the Display folder, then click on the Settings tab. You will see a linear control for the resolution that will step from one standard to the other, up or down from the current setting. Unfortunately, it won't change anything until you click on OK or Apply but it pauses after clicking shows the result then asks if you want to keep that setting.
Posted on Dec 26, 2008
johnnydiode
  • 647 Answers
SOURCE: service menu for hitachi
with power off press the source button on the front panel and then press the power on button then release - the service menu should be displayed. This works for most Hitachi's
Posted on Oct 31, 2009
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
Need codes to display service menu for esa et427e
This is a Funai product. Factory reset may be 1 2 3 4 DISPLAY. But Funai manuals I have refer to a "Service Remote" to enter service menu.
Mar 13, 2010 | ESA ET427E 27" TV
Service menu for hitachi
Oct 31, 2009 | Beko 142746 TV
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
My beko tv has a system setting on BG. I need to change it to L but it won't change. How do I change the system setting?
I need the same solution. My own system is setted up to 'I' and I want to change it to 'BG' but it doesn't work.
Jul 18, 2009 | Beko 142746 TV
Service mode
Beko TV
in main menu press 9301.Exit: TV/TXT.
Dec 03, 2008 | Beko 324250WN 28" TV
APEX 27" screen settings - service manual
Just click below for the manual;
[PDF] AT M C T
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 07, 2008 | Apex Digital AT2702 27" TV
Service Menu Code
Its unlikely that the purple splotches can be cured from the service menu.
Assuming your TV is the Magnavox 20MC4304 combi, then the tv does not have a service code. There is an alternative though.
Details can be found in the service manual:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/051111/0511110565_sma.zip&ofn=20mc4304_17.zip
May 21, 2008 | Philips Magnavox 20MC4304 20 in....
Messed with with service code menu now i dont have service with my wireless provider
it is software problem cunnect it to pc and unlock service code othewise went to sarvice center
Aug 10, 2007 | LG VX5300 Cellular Phone
Beko 324250WN 28" TV Logo
2,549 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Marvin
Marvin
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
