Question about SeatBeltsPlus.com 3 Point Seat Belt With Chrome Lift Latch
Rear retractable seatbelt is jammed
Lefthand rear seatbelt willnot come out
Seatbelt will not extract on driver side
There should be a mechanism in the door jamb near-to the seatbelt. If equipped, push on it while jerking seatbelt until it retracts. If not equipped, close door firmly while jerking seatbelt to activate retract.
May 09, 2014 | 2004 Mazda 3
I have a 2002 Chevy Tahoe and the 3 point seatbelt on the rear passenger side rear seat has been pulled out all of the way and now it won't retract back into it's holder. Is there an easy wa
The re-tractor is called an Inertia Reel. There on the side, remove the cover and there is a trigger release on most. If the spring is broken, you will need to replace the reel. Check at a local junk yard for the best price.
dc don
Sep 03, 2012 | 2002 Chevrolet Tahoe
Front seatbelt jammed
If the seat belt has jammed, you may just need to replace the mechanism- you want it to do its job correctly when you need it
For your information,--You may need to replace the mechanism for the seat belt. If the impact restraint system has encountered what they refer to as a stage one deployment due to a minor accident, the seat belt locks up, and even though the airbag(s) hasn't deployed, there are frame sensors that may need replacing reset.
We encountered this with my daughter's 05 Focus and needed to replace the belt assembly, and a couple sensors on the frame..
Dec 13, 2009 | Ford Taurus Cars & Trucks
The driver'sside front seatbelt is retracted in
Take it out and renew it ,yes its possible to to free it off but it will only jam up again .
Nov 05, 2009 | 2003 Ford Focus
Subaru legacy 93 retractable seatbelts work then dont work wat is the cause of this?is the tract dirty or something?
Are both right and left sides inop? Check the switches on the door jams. They could be going bad.Make sure they are working. Check the motors that retract the belts.
Jul 26, 2009 | 1993 Subaru Legacy
Saturn vue 2007, rear folding seat will not return to proper position due to seat belt being locked up.
They have a problem with the seatbelt retractor getting jammed up causing the belt to jam & not let the rear seat fold back up.The easiest way to get the seat back up is to cut the seatbelt & fold up the seat.Then the rear seat needs to be disassembled to gain access to the seatbelt retractor assy which has the seat belt made on.Hopefully it's still under warranty or Ext. warranty.hope this helps
May 17, 2009 | 2007 Saturn VUE FWD 4
I have a 1997 Ford Escort. The rear seat belt is stuck
make sure that the rear seats are properly locked into rear catches as this can stop your seatbels from working if ok then sounds like your seatbelt is faulty req new seatbelt.
Mar 07, 2009 | 1997 Ford Escort
1991 Toyota Camry Automatic seatbelt harness
http://www.toyotanation.com/forum/showthread.php?t=300887
Full version about Automatic Seatbelt troubleshooting for 87-91 Camry written by Professor Oleg Turkin
Jan 26, 2009 | 1991 Toyota Camry
99 maxima rear drivers side seatbelt does not retract.
Inertia reels get stuck permanantly if pulled out suddenly over time or after an accident. You may be able to remove it or pull lightly out with little tension and tap on it, if not you may need to replace the inertia reel.
Jan 06, 2009 | 2000 Nissan Maxima
SeatBeltsPlus.com 3 Point Seat Belt With Chrome Lift Latch Logo
82 people viewed this question
Top SeatBeltsPlus.com Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a SeatBeltsPlus.com Wine and Spirit Expert? Answer questions, earn points and help others
