Question about Garden
Spring to change on snowblower - Garden
  • 2,049 Answers
Mine has several springs and need to know which one.
Posted on Jan 26, 2015
Electric starter just whirs and does not engage the flywheel.Is a new starter reqd ?
PULL THE STARTER DOWN AND CHECK THE GEAR ON THE STARTER YOU SHOUD BE ABLE TO CHANGE THE GEAR AND THE SPRING THAT IS BEHIND THE GEAR THE SPRING MAY BE WEAK PLEASE REPLACE IT
Feb 15, 2015 | Toro Snowblower 826 Oxe 38624w With 3 Year...
How do I change auger drive belt
First remove the spark plug wire, then either drain the gas, or put some plastic over the gas tank opening, and put the cap over it. This should prevent gas from coming out of the vent when you tip the machine. Then follow these steps:
1. Remove the cover that goes over the belts on top of the machine just behind the sheet metal auger housing.
2. Tip the snowblower forward so that it rests on the front of the machine. This will allow you to remove the bottom skid plate.
3.Remove the skid plate.
4. There should be a spring that holds the belt-tensioner against the belts. remove one end of that spring so that the belt-tensioner can move out of the way easily.
5. Now it should be possible to remove and replace the belts. Put them on the bottom pulleys first, then you should be able to get them onto the engine pulleys.
From there, replace the tensioner spring and skid plate. Put the snowblower back on it's wheels and check the operation of the auger handle to make sure the tensioner is operating properly. Once you are happy with everything, replace the top cover. Be sure to remove the plastic from under the gas cap, refill your gas tank, and put the spark plug wire back on.
Feb 13, 2015 | Garden
How do i change the drive spring on my craftsman 4/21 snowblower
Is that the spring under the plastic hood behind the snow throwing shoot?
Dec 10, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Simplicity snowblower auger idler tension
CAN YOU CALL THE MAKER OF THAT UNIT
Jan 08, 2010 | Garden
How do I attatch the heavy spring that helps lift my snowblower to my 416-8 toro snowblower
lift the snow blower up as far as it will go and block it there, attach one end of the heavy spring to the place it attaches on the tractor now attach a come-a-long to the free end of the spring and using the come-a-long stretch out the spring until it is longer then you need it to attach to the other spot it fits on the tractor, pry it over to the spot on the tractor that it goes and slowly let off the tension on the come-a-long until the spring is firmly in its correct position on the tractor. One tip when you attach the spring to the come-a-long use a piece of rope or wire between the come-a-long hook and the end of the spring, so that you have room to attach the spring to the tractor and just remove the rope or wire when in place and you are done. Hope This Helps Don
Dec 05, 2009 | Garden
Snowblower Treads not turning
Hello, if you go to searspartsdirect.com type in your model number you will be able to find a diagram that will show you where and how the spring attaches
Mar 05, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
