Question about Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Replaced the both pulleys and blades and now when I start the mower the blades won't disengage. Model #13aj689G766
  • 1,057 Answers
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Posted on Oct 20, 2016
5 Suggested Answers
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
SOURCE: Troy-Bilt weed eater, Model TB90BC, had rotten
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
Posted on May 07, 2010
2strokeJim
  • 577 Answers
SOURCE: Troy Bilt TB320BV blower won't
unhook your switch's and see if you get spark then
Posted on Aug 01, 2011
  • 430 Answers
SOURCE: troy bilt blowr td320bv will not start. It is only 1 month old
If fuel is running out the carb then the diaghram is stiff and holding the needle open, or a piece of debris is stuck in the needle holding it open.
Either way the carb needs rebuilt.
In the future; when storing the unit; empty all fuel from the tank and start the unit and let it run the fuel out of the carb. Store it dry if its going to sit more than 30 days without being used.
Posted on Oct 15, 2012
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Put a new battery on it and still wont turn over
Check all of your safety circuits: Drive safety, blade safety, seat safety.
Naturally, ensure that your key circuit is operating.
Gary
Dec 20, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ineed the diagram for a 42 inch deck troy bilt
We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
Apr 26, 2009 | Garden
Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966 Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
