Question about Hoover Nextra HNT 2135 Top Load Washer
Hnt2135 not working
Not washing, filter OK, wash cycle doesn't start. 'Empty cycle OK
  • 883 Answers
SOURCE: all washing just smell worse when washed
there is water laying flat somewhere that will not drain completely. thoroughly check the drain hose in the back...any kinks?
Posted on Jun 08, 2007
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
  • 351 Answers
SOURCE: hoover 800 heavy duty washing machine
the clicking sound could be the brake arm worn its white and in the middle near the gear box,the reset is for water only.the outlet pump is at the back where the drain hose comes out.the filter is in the middle of the agitator just pull it out.check the belt isnt loose.
  • 30 Answers
SOURCE: washing cycle is ok but wont spin
check carbon brushes on motor
Posted on Jun 09, 2009
  • 4088 Answers
SOURCE: I have a Hoover 550 MB Top Loader washing machine
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Posted on Oct 20, 2009
Testimonial: "That is great advice . Will try and see if your solution works . cheers"
Wont drain with a load, but will drain when empty. Have cleaned filter, have run drain cycle with filter open motors works. have filled using start of 32 min cycle, and emptied using drain, at l
sounds like inside the drum a dog waste bag or a small plastic bag for something plastic has melted onto the heating element
this can be removed for checking not easy bit fiddly but at least you can rule it out
ah you think i didnt have plastic in my wash
got kids?? then the soap drawer is the place all dirty things go to get washed
sounds like some plastic flapping about above the drum drain port
Nov 28, 2014 | Candy Washing Machines
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
My fridgedaire affinity washing machine washes the clothes, then drains then starts to do a light tumble right and left. it never goes into a rinse cycle. It finally stops and shows an error code E10. I...
it could be that your rinse water valve has gone turn off all power and take the top off you can see the water valves at the back of the machine if you have a multi meter you can test the valves for continuity if ok then your filter might be blocked try the filter first
Oct 16, 2011 | Frigidaire Affinity ATF7000E Front Load...
Nextra HNWF 3135 doesn't work hole cycle, after washing stops, doesn't rinse or spin, these steps I must set up manually, because it doesn't do. I've tried to do with different programs...
Ok hot water being still there and not draining is a clog in your drain line or pump issue. I have not yet brought up the schematic to your unit but on some units there is a clean out filter located down the bottom in which you would clean out the filter careful water does come out when you unscrew the filter on other models that do not have the filter door you would remove the lower panel on the front which would give you access to the pump and the drain lines as well even though if you do find items in the filter you still need to disconnect the drain lines going to and leaving from the pump to assure that nothing is blocking or clogging the flow of water. Im glad you replyed about the hot water still being on the inside definite clog in the drain line or pump or filter issue. If you have any further questions message me back. I await your reply Thanks
Rick
Sep 25, 2011 | Hoover Nextra HNWF 3135 Front Load...
Bosch Excel 1200 washing machine stops at spin cycle, doesn't seem to be draining properly. If I open front drainage hatch to let water out the machine will start its spin cycle. Happening every wash...
Your filter will be clogged, causing the empty pump not to drain in time (usually they get about 8 minutes and fault out). If the picture I have of your machine is correct, there is a small door at the bottom of the machine on the right. Open the door, unscrew the filter, clean and replace and all should be well. NOTE: It's worth tipping the machine back by 45 degrees when you do this so any water left in the machine doesn't pour out, but having a couple of towels to hand would still be a good idea.
Please add a comment if the above has not fixed your problem and I will try to help further
Aug 23, 2011 | Bosch Washing Machines
My bosch maxx stops mid cycle and the spiral icon that represents spin starts flashing. Its seems that it can not drain or spin yet the drum rotates when washing. Now i have washing stuck and i can not...
This is almost certainly a simple problem with your empty pump filter being clogged. Without knowing the model I can't be certain, but I would suggest that the empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model, there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
In the event that this doesn't work and you just want to get your washing out, you will find that turning the machine off at the wall for 20 minutes will reset it and allow you to open the door (With the power still off). IF THERE IS WATER ABOVE THE LEVEL OF THE BOTTOM OF THE DOOR, then pull the machine out and (With some help, because it's heavy!) Tip the machine backwards at about a 45 degree angle, so that the water line falls below the door before you open it.
If the above doesn
Aug 12, 2011 | Bosch Washing Machines
My machine does part cycle than all lights flash than when restart it will start washing but want go throw the cycles ie rinse spin drain
Teh make and model of the machine is important here, because WHICH lights flash and the number of times they flash is an error code taht we can look up if you tell us the make and model. However, from what you have said so far, this likely to be a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 06, 2011 | Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hoover Nextra HNT 2135 Top Load Washer Logo
23 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
