Question about 2wire Wireless-G 802.11g ADSL Gateway
Change encryption in 2wire 590 - 2wire Wireless-G 802.11g ADSL Gateway
What is the password for the Ipod the network called 2wire 048
Unless you changed the password, it should be the same wireless key used for any portable system, on 2 wire products, it is generally on a label on the router as 2Wires are generally encrypted by default
Jul 10, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I cant get my computers linked up with the 2wire wireless router. the computer recognize the router but the passwords are not accepted
The passwords your computer requires is the router's encryption key ie. the WEP, or WPA or WPA2 key.
This encryption key can be retrieved or changed in the wireless settings of your router.
Dec 08, 2010 | 2wire Computers & Internet
I DO NOT KNOW MY SECURITY PASSPHRASE
n most cases the default wireless settings are sufficient for normal home use.
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
  1. Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
    If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
  2. Click the Home Networking tab at the top of the 2Wire Home page.
  3. Click EDIT SETTINGS located on the right panel (Status at a Glance) under the Wireless Settings heading.
  4. Change your wireless settings and use the following information if you want to change to a custom WEP key.
    64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
    128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
    64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
    128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | 2wire 2700HG-B Router (2700HGB)
HOW TO CHANGE SSID
Nov 08, 2010 | 2wire (1000-000057-000) Modem
Help setting up Panasonic DY-WL10 wireless adapter to 2Wire gateway 2701HG-B?
go to on screen "setup"
select "network"
select "Network easy setting"
Select "wireless"
do the connection check
the 2wire modem should be detected by the DY WL10
Select the 2wire
select "open system"
select WEP encryption
enter the encryption key, or just "key" (it is the number in brackets somewhere on the 2wire). Do not enter the brackets.
follow further prompts. It is easy from here on (famous last words)
Aug 15, 2010 | Panasonic DYWL10 Wireless LAN Adapter for...
I downloaded Windows 7 and my wireless laptop won't connect to my 2wire. Where can I get new security key code or info get my laptop to work?
Hey pkkern,
Your default 10 digit security is located on the bottom of your router.
If you want to change it or for some reason your default key is no longer working we will have to get into the routers configuration homepage.
To access this open up your Internet browser and write in this address, (which is your routers address) 192.168.1.254.
If your routers homepage does NOT open up check to make sure you have no software firewalls
You will see a wireless network security section, use the following information to select a custom wep-key.
Change your wireless settings and use the following information if you want to change to a custom WEP key. 64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
Thanks for using fixya!
If you need information just comment in this thread and I will get back to you, don't forget to leave feedback!
Cheers,
Jul 24, 2010 | 2wire (1000-400108-001) Router
Have 2wire gateway, need to connect netflix blu ray player
On the blue ray player they don't like encryption. I had to help a friend on that and he finally disable the encryption and it work.
Dec 27, 2009 | Gateway Wireless-B Router (wbr-100)
Lost my 10 digit Encryption Key
The 10 digit WEP encryption is located on the bottom panel of the router with the serial no. Its the default key and should work if you haven't changed it during the initial setup.
regards
Sandeep
Nov 25, 2009 | 2wire (1000-000057-000) Modem
2wire configuration
ok...
the wireless key will be located on the bottom of the wireless 2wire router not the card..look at the bottom of the 2wire box and compare the picture below you will see 10 digit key code that will be the wireless encryption for you..dae0bae.jpg
vedhick...
Feb 22, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
My 2wire router will not connect to my nintendo ds wifi system.
The DSi only works with WEP encryption. The 2Wire and most other newer routers use WPA encryption.
Simply logon to your router with a web browser. The default IP for it is 10.1.1.138 but it might be different, just check the manual or internet for the IP. Go to "Home Network" then "Advanced Settings" and change the security from WPA to WEP and save.
Thats it!
Hope that helps.
Nov 18, 2008 | 2wire (1000-000057-000) Modem
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
48 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
