Question about Troy-Bilt Garden
Troy bilt troubleshooting
Stabilizer bracket or rod will not disengage the blades. What can I do to fix this problem.
  • 246 Answers
SOURCE: mower will only run if choke is on
Hello cmsbss:
>>From your Description it Sounds like the Carburetor requires Soaking and Cleaning.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
SOURCE: owners manual for Troy Bilt Shredder Vac 47279
check this website..........brentchalmers.com
Posted on Dec 29, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Why does my Troy Bilt Pony Mower deck keep running after it is disengaged
-The belt is too tight. It should be free when the engine is running.
-Adjust it. It'll take care the problem. (I'll say it'll need about 3/4" to 1 1/2 clearance)
Good luck
mai
Sep 01, 2014 | Troy-Bilt Garden
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
Troy-bilt troubleshooting
NORMALLY THERE IS A KNOB OR LEAVER FOR YOUR PARKING BRAKE AND IS CONNECTED TO THAT PEDAL BRAKE TO LOCK IT UP FOR PARKING, THROUGH A SERIES OF RODS CHECK THOSE RODS IF STILL ATTACH TOGETHER, PRETTY SURE THAT IS THE PROBLEM, GOOD LUCK
Aug 06, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Check under your deck you could have something that is keeping your blades fro turning.
Aug 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Troy Bilt model 60TG I hit a small piece of wood and the tractor
If you haven't already, check to see if there is a hunk of wood wedged between the blade(s) and mower deck. I've seen that happen. I pried the hunk of wood out with a crowbar and life was good again. The second time, someone ran over a campfire log they didn't see under leaves last fall and bent the blade spindle. It basically froze the spindle in place even though there wasn't anything wedged in there. I removed the belt from the top of the mower deck and then it started just fine..... although the blades and shaft were toast and had to be replaced. If you can disengage the mower deck without removing the belt(s), try it if you haven't already. See if it starts that way. If not, the issue may be more serious such as a broken connecting rod in the engine. Try the simple stuff above first to troubleshoot the cause.
Apr 30, 2010 | Garden
Ineed the diagram for a 42 inch deck troy bilt
We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
Apr 26, 2009 | Garden
Garden Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
