Question about GE DBSR453EBWW Electric Dryer
Why is the dryer making squicky noises when working?
    Sergeant:
  • 435 Answers
Bad drum bearing, bad drum teflon pads or both possibly
Posted on Feb 09, 2015
07sti wrx is making squicky noise from back finder side
Could be the ball bearings or the break needs changing.
Oct 05, 2012 | Cars & Trucks
I have Kenmore washer. Anytime the selection is on cold, warm and cold, hot and cold the washer makes squicky noise and very little water come out even though both hot and cold water are open. the only...
from what you said it sounds like you have a problem with cold water coming into the machine,shut off the house water valve,remove the water lines off the back of the washer and mark them so you'll know where the connect when you put them back onto the washer,stick them in a backet or in the tub of the washer,turn the water on,if the water comes out strong then you have a problem with the water valve on the washer,see if you can pull out the screens out of the valve and clean them but most likely you'll need to replace the valve.if the water doesn't come out strong then you have a problem with the house water
Feb 22, 2011 | Kenmore Washing Machines
How do i stop the squicky sound when going over speed bumps and breaking.my vehicle makes a lots of noise so loud people no its me coming.
Get the truck oil under coated and check the shocks to see if they need replaced and the brake pads have pins on them that scream when they are ready to be replaced.
Feb 20, 2011 | 1998 Ford Explorer
My Stratus seems to be making this unusual noise I brought it to an auto repair and they changed all the belts it stills makes the squicky noise. I don't know what it could be or what to fix could you give...
BELT TENSIONER TOO WEAK.CAUSING BELT TO SLIP AND SQUEAK.OR YOU HAVE FLUID LEAK GETTING ON BELT OR YOU HAVE WORN GLAZED PULLEYS THEY WILL SQUEAK.
Jul 01, 2010 | 2005 Dodge Stratus
Dryer makes squicky noise while drying
its the drum glides/slides that support the front part of the drum open the door and push on the door switch and start the dryer and you will be able to locate the noise source easily
Apr 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a scrubbing noise then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
djdgh
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
It make a loud squicky sound when wet close are in it as if the drum is scrubbing some metal
Bering has worn out, spraying it with some active oil would moisture it for a while, but it will need to be replaced.
Jun 28, 2009 | GE DNCD450EA Electric Dryer
MY Kia Rio 2005 has a squeky noise on the pulley
then you are going to have to remove the timing cover and see which it is water pump ,ect all which the timing belt drives
Jun 22, 2009 | 2005 Kia Rio
Fisher & Paykel top load electric dyer makes loud squeaky sound
to be honest i doubt that a bad belt would make a squicky noise and for a high class dryer like that i would suggest just call repairman  they are very complex
Jun 08, 2009 | Fisher and Paykel DEGX1 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
70 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
