Question about Relisys TL 766 Monitor
Horizontal black lines across the screen
I have Relisys 17" colour TFT monitor 4 years old, I recently started to get horizontal black lines across the screen,first they started to appear after 2 hours from use, now after 20 minutes up to 2 hours from swiching monitor on,sometime they disappear after few minutes,or not and screen becomes shacky,if I swich the monitor off briefly but keeping PC on,then swiching the monitor back again,the problem appears to be resolved and monitor works find,on other occasions the lines remains after reswiching the monitor,I heard Relisys has sold their business in the UK and do not know how to get support from them or possibly repairing the monitor by them at cost,any one can help?many thanks.
  • Ali Mohammed Jun 19, 2009
    Hi,many thanks for the reply,I have contacted lumarco and waiting for their reply,I am considering buying new one but want to be sure if the monitor is actually faulty and the problem is not caused by other PC components.
  • Ali Mohammed Jul 07, 2009
    Lumaco has replied and identified the problem,which is located in the power supply board,may be chip or transistor heating up,the problem has resolved and the horizontal black lines has disappeared since.thanks
  • 400 Answers
You can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Posted on Jun 19, 2009
  • Fabio Jun 19, 2009
    The only way to test that is to connect the monitor to another computer.
    Don't forget to rate my solution when you get it sorted .
    Thank You
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
I got horizontal lines occasionally across my Relisys 17'' TL766 black monitor,sometime they disappears when I turn monitor off and on again,sometime not,what is causing them
try to open back cover and remove / insert all connector that you can found including ribbon wire check also soldered side for possible lost contact.
Apr 10, 2010 | Relisys TL 766 Monitor
Dell monitor E172FPT HAS GOT BLACK LINES ACROSS THE BOTTOM OF THE SCREEN HORIZONTLY??
Click the Menu button and use the '+' & '-' signs to select restore factory settings. Check if you get the same line in the BIOS screen, if so then you would need a replacement.
Nov 14, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Horizontal lines lcd monitor
I think monitor is defective. Contact manufature
Dec 13, 2007 | Relisys RLT1720 17" LCD Monitor
Monitor problems
Try plugging in another known working monitor and see what happens. That will tell you whether the issue is with the monitor or your HP. And do not go to HP for assistance since they will not do squat for you - horrible support and not deserving of business.
May 02, 2017 | Daewoo 17N5 17 in.CRT Conventional Monitor
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Jan 18, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Relisys TL 766 Monitor Logo
306 people viewed this question
Top Relisys Computers & Internet Experts
Marvin
Marvin
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
