Question about Maytag Dryers
Maytag 5000 series dryer won't turn on - Maytag Dryers
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My 5000 MayTag Dryer is
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Feb 28, 2011
oldTech2332
  • 2341 Answers
SOURCE: Maytag dryer mde308dayw won't turn on
The most probable thing thats wrong causing the dryer to not start is going to be a blown thermal fuse,when it goes out it cuts power to the motor circuit...do you have a display on the front yet it wont start???? or no display??
If you do have a display yet the dryer wont start it very likely will be the thermal fuse,it fits into the blower housing below where the lint filter fits into inside of the door,or depending on your model it will be in the rear but in any case it will be in the blower housing below where the lint filter fits all be it in the front or rear, To access it to check it remove the small lower front panel or the rear panel if it comes off(if not its going to be in the front) and it will be on the top of the blower housing,to check it measure it for continuity (ohm it out) with zero ohms resistiance.
This is what it looks like in the pictures below,either one of these two styles.
If that turns out to be the problem be sure to take apart the blower asm. and clean all lint from it and also check the venting from the back of the dryer all the way to where it exits the house....since the usual reason the thermal fuse goes out is because of poor airflow because of built up lint/blocked vent.
GENE
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Posted on Sep 24, 2011
hunter19_46m
  • 7482 Answers
SOURCE: maytag dryer won't turn on and start cycle
Hi Calvin D Robinson Jr.
Here are a few things to check
**************************************************************************ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Posted on Oct 07, 2012
How do I disassemble a maytag 5000 series dryer to replace drum support wheels
Go to www.repairclinic.com and enter model 5000. You will be presented with a list of common replacement parts and may be able to vies a generic Maytag video showing disassembly and identification of parts.
Oct 30, 2016 | Maytag Dryers
Want to side mount dryer vent hose.
There should be what is called a knock-out panel on the side of the cabinet that is 4 inches in diameter... then you need the adapter kit to route the exhaust 90 degrees to the side... https://www.google.com/aclk?sa=l&ai=DChcSEwicp73NkufPAhWFMWkKHYu9BWsYABAT&sig=AOD64_1Cjzub4z0RkLpGJ6plZANoOKacbA&ctype=5&q=&ved=0ahUKEwjbsbjNkufPAhUo8IMKHU0cANsQvhcIMA&adurl=
Oct 15, 2016 | Maytag Dryers
Loud squeaky noise on Maytag 5000 series dryer
You most likely need a new dryer drum belt.. Are you going to tear it down and do the job yourself?
Sep 26, 2016 | Maytag Dryers
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Series 5000 dryer error code f01. What is wrong and how do I solve it?
The error code f01 indicates the primary control board failure. Before you replace that board I suggest that you unplug the dryer for 2 minutes then see if the error come back. If it does replace the board
Aug 19, 2013 | Maytag Dryers
Manual for Maytag 5000 series with steam
Hello, am having some problems with my MAYTAG 5000SERIES WITH STEAM. i cannot operate with it!
Aug 13, 2012 | Maytag Dryers
Screen reads CF1, and does not work
Maytag 3000 series .Dryer screen reads CF1, then CF2... then Cf3 and does not work
Apr 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
Dryers Logo
21 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
