Question about Weedeater Gas Powered Hedgetrimmer Ght225le
How to test a coil - Weedeater Gas Powered Hedgetrimmer Ght225le
P0351 code loss of power 2.3L08ford ranger,it warms slow and really need to eliminate1~voltage regulator is where?) & 2~ ground through PCM) 3~knowing limits&threashholds{sensorsIGNcircuit}?Ty 0$
P0351 loss of power ? That's not what this code is about . P0351 - Ignition Coil A Primary/Secondary Circuit ,you have a bad coil and possibly a bad coil driver inside the PCM . Do yourself a favor an take your vehicle to a qualified repair shop !
P0351 - Ignition Coil A Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0350 - Ignition Coil Primary/Secondary Circuit Description: Each ignition primary circuit is continuously monitored. The test fails when the powertrain control module (PCM) does not receive a valid ignition diagnostic monitor (IDM) pulse signal from the ignition module (integrated in the PCM). Possible Causes:
  • Open or short in the ignition START/RUN circuit
  • Open coil driver circuit
  • Coil driver circuit short to ground
  • Damaged coil
  • Coil driver circuit short to VPWR
Diagnostic Aids: Use the 12-volt non-powered test lamp to verify START/RUN voltage at the ignition coil harness connector.
Check the coil driver circuit for open, short to VPWR, or short to ground. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test JE .
Feb 18, 2017 | 2008 Ford Ranger
I HAVE REPLACED THE COIL PACKS AND THE COMPUTER ON MY 2006 F150,BUT I STILL GET AN ERROR CODE OF 352.WHY IS THIS ?
P0352 - Ignition Coil B Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
  • Open or short in the Ignition START/RUN circuit
  • Coil driver circuit shorted to ground
  • Damaged coil
  • Coil driver circuit shorted to VPWR
Check the coil driver circuit for open, short to VPWR, or short to ground. Application Key On Engine Off Key On Engine Running Continuous Memory Coil pack ignition testing GO to Pinpoint Test JC . Coil-on-plug (COP) ignition testing GO to Pinpoint Test JB . Without me testing , it's hard to say what you got going on ! Coil packs ? What engine does it have ? 5.4 L ? should have coil on plug ignition .
Jan 13, 2017 | 2006 Ford F-150 Regular
No spark at spark plug could the coil be bad and how do you test it ?
put an insulation screw driver in the wire end that connects to the cap, obviously disconnecting it from the cap. Crank over and move metal part of screw driver next to some metal and you should see a spark coming from the wire to ground if coil is good.
Feb 14, 2016 | ATVs
How do I check the ignition coil
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is zero point five and zero point seven ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
Jul 30, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
Bike has no spark
Check your pick-up sensor located inside the timing cover, behind the adjustor plate. If the filament is not intact you will have no spark.
A defective coil, cam position sensor, or stator will also cause a no spark condition.
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Test Results
May 09, 2014 | 2002 Harley Davidson XL Sportster 883
How to check for spark, harley springer
Test Results
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
Throttle cable install
What year????
For some models and years, but do not know if it fits yours as I do not know what year you have:
Test Results
May 03, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
I have an 05 softail duece with manual choke, engine will turn over fine but I have no fire at the plugs, installed new plugs, still no fire
Test Results
Apr 28, 2014 | 2005 Harley Davidson FXSTD - FXSTDI...
Pilot will lite but burner will not when you go from pilot to on
Hi.
When this happens it usually means that one of the coils is defective. The burner valve is operated by three or two coils. If one of the coils is bad the pilot will lit but the valve won't stay open when the oven is supposed to turn on.
Test the coils reading impedance at their contacts. If a coil is open (shows Ohms infinity at the multimeter reading), then the coil must be replaced.
If the coils are fine test the thermostats (always reading impedance) and replace the coils if thermostats are fine. Check also pressure regulator and ensure that the flame is OK.
Other part that could cause the problem is the flame sensor. The flame sensor is difficult to test and fails really uncommonly. The sensor works in parallel with the coils. The part is tested reading Volts. Flame sensor is usually tested and replaced only when there is no other possible cause for the problem, after testing coils and thermostats and eventually replacing coils.
Regards.
Ginko
I
Jul 20, 2011 | Kitchen Ranges
I have a first generation 83 yamaha venture 1200 v 4 i have power to only 3 of the ignition coils the fourth coil has tested good by taking #3 lead and plugging into #4 coil. any ideas on what part to...
Okay...when you say power to the coil...I think you mean getting a spark on the plug wire?
All 4 coils should have battery voltage on the red/white wire to each coil. The second wire returns to the igniter (TCI....ignition black box) and it switches that wire off and on to ground to cause the coils to fire. If all 4 test good...then
Check out the TCI, the large box mounted on the coil rack that the connectors are clean.
Now remove the 6 wire connector from the TCI...and test the resistance of the pickup coils which are located under the left crankcase cover beside the stator coil.
you will be testing the following wire pairs on the 6 wire connector
Orange-Black
White/Red-Black
Gray-Black
White/Green-Black
You should see at ambient engine temp...about 110 ohms resistance on all 4 pairs.....if one pair is showing no resistance...you need to test at the lower 5 wire connector just below the seat left side with the same 5 colors....unhook and test....if still having one bad test...pickup coils may be bad.
Apr 10, 2011 | Yamaha Royal Star Venture Motorcycles
Weedeater Gas Powered Hedgetrimmer Ght225le Logo
27 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
