Question about Tornado CV 30 Vacuum
Tornado CV30 vacuum stopped working after getting too hot.
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Hi: We ahve a
To clear the clog, remove the hose and wand from the unit and separate them. The hose is released by pressing the white plastic ring in the housing. The two are separated by simply unscrewing them. Remember this threaded connection uses a left-handed, or reverse, thread. By looking through each of these pieces, the user can ensure they are not clogged. To check the lower hose, it is easiest to lay the unit on its side. Remove the glide sole by turning the yellow turn locks to line up with the slots and then removing the glide sole. Remove the yellow connector the wand was plugged into. You should be able to see the brush through the hose from the rear of the machine.
Posted on Dec 21, 2010
Tornado Piranha 2-Speed Floor Cleaner Machine will not turn on
If you get nothing on any speed, the first thing to check is whether you're getting power. The most common failure is the plug ( the part you put into the wall socket ) You can buy a replacement plug at any hardware store or you can take it to your local vacuum repair shop and have it fixed.
Dec 18, 2014 | Tornado Piranha 20" 2-Speed Floor Cleaner...
What is a tornado
a tornado it a brand of vacuum cleaner perfectly safe to be around
Mar 24, 2014 | Tornado B352-2401: Piranha True HEPA...
Why does the beater brush belt keep breaking?
The belt on this model series will break if the roller stops spinning or spins with high amount of resistance. Remove the brush roller and check that it will spin freely, if it does not it would need repair or replacement.
Jan 21, 2014 | Tornado CK 14/1 QD Vacuum
Replace belt
Is Tornado the brand name of the vac or just the model name? And I will need the model number to look up a schematic for it. Thanks
Dec 11, 2013 | Tornado VACUUM CV38 - 15" Vacuum
Tornado cv30
Sound like the beater bar is full of hair and other debris causing
the motor to be under too much of a load. Extract the beater bar
and clean it. The bearings at each end may also need to
be lubricated or replaced. The should turn real easy.
Oct 16, 2013 | Broan-NuTone Vacuums
Tornado cv30 1
will shut down if the motor over heats check for blocked filters
Tornado vacuum overheating
Overheating can be caused by several things. First check the bag and filters, clean or replace them if needed. Also check the suction path for any clogs or obstructions. Most vacuums have a thermal cutoff designed for safety to turn off the motor in the event of getting too hot. If all of the above does not solve the issue, the next to look at would be electrical connections and checked out by a qualified technician.
Jan 12, 2013 | Tornado CV 30 Vacuum
I have a Tornado cordless chain saw. I have lost user guide. How do I oil this chain saw?
Google on line and ask for a user manual giving the name, product model number of equipment you are in need of an instruction guide.
Apr 03, 2011 | Tornado CW50 - 91450 Bagged Upright Vacuum
Can I get a parts book on the Tornado Karcher CW50? I need to order parts. Thank You
Karcher doesn't publish a parts manual, but there are numerous sites like this one that offer diagrams and allow you to order from a picture.
Oct 12, 2010 | Tornado CW50 - 91450 Bagged Upright Vacuum
Tornado CV 30 Vacuum Logo
91 people viewed this question
Top Tornado Vacuums Experts
JoeVacs
Are you a Tornado Vacuum Expert? Answer questions, earn points and help others
