Question about Facebook Apps
Palm cantro no in caming calls
No in cming calls
2 Suggested Answers
SOURCE: palm cantro keeps hot syncing can not use my phone
yeah mine did the exact same thing and now it wont turn on at all and all i can see is the red charging light :(
Posted on Dec 08, 2009
Palm cantro keeps hot syncing can not use my phone
this has also happened to mine like yesterday, dont remove the battery mine wont turn back on now, try letting it charge overnight withoout touching it at all
Oct 23, 2009 | Palm Treo 500 Centro
Palm Centro - continous Syncing problem, now phone is dead
This happened to my palm centro and i fixed it myself. :) Maybe it will work for you. What i did was take out the battery and so the phone is completely off.. then take a tooth brush with rubbing alchohol on it and scrubbed the bottom part of it that the hotsync cord goes into.. I thought this may just mess up my phone more but i plugged it back into the power cord, turned it on and it worked just fine!! Seriously, try this out. It brought me so much relief!! And chances are you either got some **** stuck up inside there, or you got the botton part wet. Hope i helped!!
Aug 24, 2009 | Palm Treo 500 Centro
Palm TX two Batteries?
Actually palm depend on main battery thats why system doesnt let it to drain to protect the data. However its true that there is such thing called "External battery" or "Battery Extender" Basically its a simple battery pack. Its convenient when you far away to AC outlet. It usually looks like this fc446ce.jpg
Jul 12, 2009 | Palm TX Handheld
Hot sync with vista
I have Vista Home Premium and I hotsync my peg-n760c using Palm Desktop. It came with version 4.1, but it was a disaster. The Cd is old and isn't compatible with Vista. So I downloaded an upgrade from Palm.com and I definitely don't use the Jukebox software that came with it either. Go to Palm.com and download PalmDesktop Win62.exe and install it. It should recognize your USB connection and hotsync immediately. Also, use Windows Media Player and change the files to mp3 by using a free program called Switch. Just google Switch and download the basic program. Then load the mp3 files onto your memory stick in Windows Explorer. Then use MSimport to load the memory stick files into your handheld. Good luck!
terymo2
Jan 31, 2008 | Sony CLIE PEG-N760C Handheld
How to HotSync Clie' and Palm Zire
install it on another computer buy her a computer
Sep 19, 2005 | Sony CLIE PEG-TG50 Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palmâ„¢ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
How do I get outlook & my palm to sync?
Hi, if u want to sync with outlook , u would either have to buy the installiation disc from palm online store or call up tech support , it will cost u, or if you want u call also chapura and buy the outlook conduits from them , u dont get the outlook conduits on the website . In the installiation disc u get the outlook conduits . Regards
Sep 11, 2005 | Palm Tungsten E Handheld
My hot sync was working fine and now it will not communicate... I have tried everything listed on your website but nothing seems to work please help
My Palm stopped syncing on both my work and home computer at the same time. I have been syncing fine with XP and USB. I found a thread where someone mentioned getting Palm to send you a Palm Reset Card. I called Palm and they didn't offer this solution, but I asked for the Palm Reset Card and it worked beautifully! They took my call and sent the Reset Card no charge. Unfortunately, nobody at Palm seems to know about this solution.
Sep 11, 2005 | Palm Vx Handheld
Facebook Apps Logo
12 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
