Question about RCA M4604 (4 GB) MP3 Player
My rcaeasyrip_setup.exeis not compatable with windows 8
    Problem Solver:
  • 15 Answers
You should get one from the RCA site.
Posted on Sep 06, 2014
When I go into set-up, the onlything I can do is to cancel the program. I want to set up my new fitbit for use. What should I do?
Did you go to the Fitbit website and click Setup? It should tell you if the device is compatible with the Vista OS once you do that. If it is not, you probably ought to go through that webpages setup on a computer with a newer operating system. You don't even have to have the device to check whether setup will work on the praticular OS. You just run the setup from the webpage on any computer that has either Windows 7 or Windows 8 to check out what OS's are covered. Elsewise, you contact support.
Fitbit website will not run the setup on XP machines so it might simply be a matter of OS compatibility. Painful as it is to accept, all new hardware is simply not going to have software written compatible with legacy machines. If the product says "works on all Windows systems", you might contact their support but I can not envision them assigning someone to work out a code compatible with Vista due to market size.
Jan 20, 2015 | Computers & Internet
Tip
How to Install any Driver/Software which isn't Supported by Windows Vista/7
Hello!!
There are lots of old Soft-wares and Drivers available which are not compatible with Higher Version of Windwos.
So some Windows XP exclusive setups can be installed under Windows Vista/7 As Under.
1. Try to install the drivers in compatibility mode.
2. For that right click on setup.
3. Go to properties.
4. Go to compatibility Tab.
5. Set it to win xp sp2.
6. Hit ok
7. Run setup as administrator
8. Ignore any error and hit continue anyway during installation
9. Restart pc
If the above trick doesn't work, then use the device in VIRTUAL XP MACHINE
You can use XP MODE or VMWARE or any other Virtal Machine Application.
Hope it Helps..!!
on Jul 13, 2011 | Computers & Internet
Konica minolta page pro 1380 MF compatibility with windows 8
Solution for my 1380MF on 64 bit Windows 8:
Download Windows 7 driver from http://onyxftp.mykonicaminolta.com/download/Search.aspx
Enable third-party INF install: http://www.youtube.com/watch?v=dlYGfJM2BJ0
Run Setup.exe.
Profit.
Feb 03, 2013 | Konica Minolta Office Equipment & Supplies
Is the Wireless N 150 Ultra Compact USB 2.0 Adapter compatible with Windows 8 ?
Make sure you are on Windows 8 Desktop. Try download the Buffalo WLI-UC-GNM_E-105 driver and run setup.exe with XP SP3 compatible. After the installation, your Wireless-N150 Ultra-Compact USB 2.0 Adapter will be working fine in OS Windows 8.
Nov 03, 2012 | Buffalo Technology N-Technology...
Screen resolution low there for windows 8 donot work perly needed 1024
ASUS only has XP drivers Download from ASUS
http://www.asus.com/Eee/Eee_PC/Eee_PC_1000H/#download
VGA_XP_080630.zip: Unzip and run setup in Compatibility Mode by selecting setup and use Troubleshoot Compatibility. Click on Troubleshoot Program > Select 1st option "The program worked in earlier version of Windows..." Choose XP and Start the Program.
Oct 06, 2012 | ASUS Eee PC 1000H Laptop
My mom will only use CreataCard Gold 3 but uses Windows 7. How can she still keep using it?
Does the software install properly in Windows 7? If you are having installation problem then you can try running the installer (most of the time it is "setup.exe") in "compatibility mode".
To run a program in comparability mode right click on the executable (i.e "setup.exe") and select "properties" then click on the "Compatibility" tab. In the "Compatibility" tab select the check mark next to "Run this program in compatibility mode for:" option then from the pull down menu select "Windows XP (Service Pack 2 or 3)".
After installing the program if you run into issues while using the program then use the same steps to run the program in Windows XP compatibility mode.
Sep 06, 2011 | Broderbund American Greetings Creatacard...
I've upgraded my computer n hv windows 7 n my scanner Umax Astra 5600 does not operate on the new computer. I need yr help in getting the driver for windows 7 for my Umax Astra 5600.
most old scanner are not working with windows 7 and also 64bit of win 7
VueScan is bringing them to life ;)
http://www.hamrick.com/
Feb 28, 2011 | Computers & Internet
Error code 0x24050010 Canon scan N640P in windows 7. please please help me...
What you need to do is run the driver setup in windows XP compatibility mode.
Right click on the setup icon, select properties, compatibilities tab then select Windows XP SP3 (or some older version of Windows.
Then left click on the "Change settings for all users" button and from the new window select again XP service pack 3 compatibility and check the "Run this program as an administrator". Click OK and then run the setup application.
It worked for me on Windows 7 ultimate.
Sep 16, 2010 | Canon CanoScan N640P Flatbed Scanner
Compatability issue
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Jul 09, 2010 | Broderbund American Greetings Creatacard...
I am trying to install creatacard 8 on windows xp home. it freezes at 8% installing fonts. i have installed this before on my computer and this time it does not work.
I have the same problem when trying to install on Vista (Home version), except it freezes at 4% intalling fonts. Have tried to adjust setup.exe properties to compatible options, still doesn't work. Also used Windows Vista compatability wizard with no luck.
Aug 22, 2009 | Broderbund American Greetings Creatacard...
RCA M4604 (4 GB) MP3 Player Logo
43 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
