Question about Panasonic NN-S255 Microwave Oven
Panasonic microwave motor
Not turning
Microwave oven turntable keeps running
Your control board is defective , please check also your connections to the motor.
Feb 17, 2016 | Panasonic Microwave Ovens
How do I fix my turn table in microwave sn676s
Most Microwave turntables are driven by a small motor under ther bottom. They usually have a small access panel on the bottom that covers the motor.Remove panel and you will see motor with 2 wires going to it. 1 or 2 screws hold stirrer motor in place.
Feb 28, 2015 | Panasonic NNSN657S Microwave Oven
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Panasonic NNA873SB, turntable is no more turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Dec 04, 2013 | Panasonic NN-A811A Convection/Microwave...
Panasonic nn ct766 turntable locked
If everything cooks as normal but the turntable does not turn then I would say that either the turntable motor has failed or the supply for the motor, either way this is not a problem you could fix yourself & so I would recommend taking to a microwave repair centre or service engineer.
Dec 26, 2012 | Microwave Ovens
Panasonic 28 L NN C784 MF Cov+BAke. Turns off automatically after 20 secs every time. It once displayed HOT message too. Even after 24 hours of last operation the MW turns off automatically after...
hi,
look in the back through the grille with a flashlight to see if the cooling fan is running, you should feel a slight draft there too. if not running take the cover off and oil the magnetron cooling fan with 3 in1 sewing machine oil. oil it on both sides of the motor so its saturated. if it does it again you will have to order that motor. probably at panasonic.com or searspartsdirect.com. be careful inside the microwave with the cover off, avoid the red high voltage wires. use gloves if necessary. panasonics are a pretty good oven, worth fixing..
jm
Apr 25, 2011 | Panasonic NNH965BF Microwave Oven
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Panasonic NN-S740BA Microwave oven
In all likelihood the mangnetron is failed or failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Jan 27, 2010 | Panasonic NN-S740BA Microwave Oven
Panasonic NN-S255 Microwave Oven Logo
19 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
