Question about John Deere 3.5 cu.ft. Broadcast Spreader LPBS36JD
Repair Spreader door
SlimJim my 05 Dodge Magnum
https://www.bing.com/videos/search?q=how+to+slim+jim+05+dodge+magnum&FORM=HDRSC3
Apr 17, 2017 | Dodge Cars & Trucks
Tip
DIY Tension Spring Spreader..... for working on front load washing machines. ...
To work on a front load washer, door seal or lock, one needs to remove the wire/spring clamp from the rubber door seal. It can be removed easily but reinstalling it can be a nightmare, it requires the spring to be extended while slipping the wire around and into a slot.
They sell a tension spring tool for about $45.00 CAN, I made one for about $20.00 and it can still be used as wood clamp in the shop. See attached photo.
I bought a Dewalt 6 inch Trigger Clamp, took out the pin and reversed the trigger, it now becomes a spreader.
Cut the sharp ends off of 2 - 2 inch nails and file a small groove at the ends, they become the spreader posts.
To attach the posts, drill 3 or 4 small holes thru the plastic clamps, then use some wire to fix the posts securely, you may also us some tape to hold the post when there is no tension on the posts.
As you squeeze the trigger it expands the spring, the wire/spring clamp was reinstalled within 30 seconds without damaging the rubber seal.
Now that the washer is repaired I will put the clamp to work in my shop.
on Apr 28, 2017 | Washing Machines
I have a speedy green 1000 and the drop chute will not close is there a repair kit for this machine?
Phil, Check the attached links,instruction and guides contact Scotts if you have to. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Help Center Contact Lawn and Grass Experts Scotts
Scotts Speedygreen 1000 law spreader spring repair
Replacing Rusted Axle on Scotts Speedy Green Spreader
scotts speedy green 1000 parts diagram Google Search
Apr 15, 2015 | Scotts Company Scotts& Accugreeen 2000...
Repair broadcast spreader
ACE might be able to advise you on this issue.
Apr 03, 2014 | ACE R Broadcast Spreader - Set of 2
Cyclone spreader parts
Cyclone spreader parts can be purchased from amazon, take a look here: Amazon com Cyclone spreader parts. Wish you best of luck
May 16, 2012 | Garden
The little door on the hopper of my Scotts Speedy Green 1000 spreader does not close when I release the contol handle. Is there a spring that has come off and can a replacement part be purchased? Dennis
Hi Dennis. I don't think there are any after market parts for Scotts spreaders. I do recall a wire and a spring on one type of Scotts spreader. There was an eyelet hole just off center that the wire and spring attached to. You could probably rig something up pretty easy. Would be a matter of locating a spring and wire.
Before you get to deep into this... flip it over and look for dried / caked fertilizer on next to thehinge area. I have seen this stop spreader application doors from closing often.
You can ask Scotts here:
http://www.scotts.com/smg/helpcenter/helpCenter.jsp
Kelly
Apr 26, 2011 | Scotts Company Garden
Precise fit 85 lb tow broadcast spreader Can't find repair parts for precise fit spreader
repair parts can be found on amazon, click here and take a look: Amazon com Precise spreader parts. I hope this was helpful. Cheers
Apr 18, 2011 | Garden
John Deere 3.5 cu.ft. Broadcast Spreader LPBS36JD Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
