Question about OEM 2000 Cadillac Deville Radio / CD Player g63314412i AM-stereo-FM-stereo-cassette opt UT0 Topeka, Kansas
2000 deville bose stereo wire color codes - OEM 2000 Cadillac Deville Radio / CD Player g63314412i AM-stereo-FM-stereo-cassette opt UT0 Topeka, Kansas
How do I integrate an aftermarket deck into the Bose system in my 2001 DeVille, factory radio plug in has been cut, and is long gone
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
The best way to do this would be to get a plug from the junk yard..colors should match up and them get the correct integration harnes.
Aug 22, 2016 | Cars & Trucks
2007 Nissan Altima Stereo Wiring Diagram for Bose Navigation
None are actually color coded. The schematic has the wire colors on it next to the wire.
May 01, 2014 | 2007 Nissan Altima 3.5 Sedan
Wiring color code radio
Here is what I show from the manual.
2005 Hummer H2 Car Audio Installation Guide
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Apr 01, 2014 | 2005 Hummer H2
WHAT ARE THE SPEAKER COLOR CODES
2000 Cadillac Deville Car Stereo Wiring Diagram, SPEAKERS ARE HILITED
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6?
Car Audio Rear Speakers Location: Rear Deck
Mar 29, 2011 | 2000 Cadillac DeVille
I need a stereo wiring diagram for a 1997 Cadillac Deville D'elegance
Here's your color codes at least. I hope this helps you and good luck.
1997 Cadillac Deville Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 5 1/4" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Mar 24, 2011 | 1997 Cadillac DeVille
1997 cadillac deville theftlock activated bose stereo
There should be a code in your manual in the section about the radio, or in the section about electrical maintenance. This lockout is triggered every time the battery is disconnected.
Feb 28, 2011 | 1997 Cadillac DeVille
My car stereo was stole they cut the factory wiring harness from the durango i need to know the color codes of the wires please
That's hard to answer cause it depends on how far back on the wire harness they cut. Plus if you have a Bose system or not. I would highly suggest to take it into a stereo install shop to at least check it out but maybe install the new stereo.
There is a wiring color code that all vehicles use but if the wires have been cut to far back they will be different colors. If you have a factory amp then you will have to rewire for the speakers to bypass it.
I added below the color code. Make sure you disconnect your battery before you start wiring anything.
Please note: You can do major damage to your truck computer and other components if you wire it wrong.
Proceed at your own risk
moz-screenshot.pnghttp://i.ehow.com/images/a05/32/br/hardwire-car-stereo-800X800.jpg
Feb 26, 2011 | Dodge Car Audio & Video
What is the color codes for the radio of a 1994 cadillac sedan deville? the ends have been cut, so cant use a harness
from the factory service manual radio diagrams.
1994 Cadillac Deville Sedan Car Radio Wiring Guide
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 6′ x 9′
Apr 07, 2010 | 1994 Cadillac DeVille
Need help finding a wire diagram for a bose stereo in 2000 jimmy
speakers aren't fused, You have a wiring problem
Jun 26, 2009 | 2000 GMC Jimmy
OEM 2000 Cadillac Deville Radio / CD Player g63314412i AM-stereo-FM-stereo-cassette opt UT0 Topeka, Kansas Logo
65 people viewed this question
Top OEM Car Audio & Video Experts
D. E. Hev
wadingriver
wadingriver
Are you an OEM Car Audio and Video Expert? Answer questions, earn points and help others
