Question about Acer AL1717 17" LCD Monitor
Power problem my pc have acer lcd 17" silver colour monitor . just today when i open my pc , nothing come on my monitor .but my pc was on . i check all wire everything right.i check monitor power button thr green light was blinking after 2 minut suddenly display shown automatic . after that i work few time and then again close pc . when again i on pc same problem happen. power button light is blinking and display come after 2 minut. what is it ?
    Sergeant:
  • 321 Answers
Low power consubtion first on ur moniter then cpu
Posted on Jun 19, 2009
Dear sir, my lcd monitor 17"
> after getting Internet connection of my PC, that trouble came.
That probably has _NO_ affect on your LCD monitor.
You could either:
* live with the problem, spending NO money
* spend $50 to $75 for a TV/audio/video technician to try to fix it
* spend $50 to $75 to buy a used 17" LCD monitor
* spend $100 to $150 to buy a new 19" LCD monitor
Nov 12, 2010 | Acer Computers & Internet
AL1715 (Black, Silver) 17" LCD Monitor: my problem is not computer i am computer problem i...
The problem with PC or the monitor?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
The color on the monitor suddenly has a blue tint that I am not able to change.
have you removed any of the VGA connectors at all ? - have a look on the plugs for a bent pin - quite a common issue on VGA plugs - that even when bent they will still screw into the socket and depending on which pin you can get a colour shift
Apr 12, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Doisplay menu comes on for nothing
annalyca, If you can swap-in a KNOWN GOOD monitor to prove pc is ok, then you will know monitor is probably at fault. When very strange and weird things begin to appear on the lcd panel for no reason at all, I would first suspect that the units "switch-mode-power-supply" will need to be checked for proper output voltage and noise levels are within specification. SMPS's by design are "noise dirty" to begin with, and that's what makes them CHEAP. Hope this was of some help.
12fixlouie
Feb 03, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Screen has red dots all over the picture
its look like your lcd panel is getting break down. need to take to service.
May 19, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
Trailing of discolouration when mouse moved
Got it working by adjusting the hardware acceleration.
Nov 25, 2008 | Acer AL1715s (Silver) 17" LCD Monitor
No power to monitor
if no power of monitor. firstly Check Power Code .Power Code Is Ok Then Chek Monitor Circuit . power section . firestly Check Fuse On Pcb And Check Power Section Component Mosfet And Diode,
Dec 28, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Black Mark
only sounds as if he has damaged the pixels so much they don't display the colour properly any more, if it is still under warranty get it replaced by Acer, if not take it to an electronics store like pc world and they might be able to fix it for a price.
Martin,
Dec 01, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1717 17" LCD Monitor Logo
495 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
