Question about Verbatim Insight 320gb Portable External Usb Hard Drive Model Is320
Unsupported format not recognized , "unsupported format"
My sd card is not recognized all of a sudden.
Try reformatting it and see what happens. If you have material that you want on it, see if you can first get some freeware to retrieve the files. It does exist.
Then format.
Oct 24, 2016 | Cell Phones
I get "card access error" on my 1315 printer I cleaned the conector with no results the computer recognizes the disk help !
There may be some glitch, check for updates. Format the card (check what format printer support), card may be to big in space, or unsupported model...
My advice is don't bother, you will lose a lot of time and effort and gain very little. If computer recognizes the card, just go from there.
Apr 14, 2016 | HP PSC 1315 All-in-One Printer
Can not read HD
If it recognizes, but cannot read it, then it is in an unsupported format (PC's do not recognize Mac OS Journaled, and vice versa). If it is not recognized as an active drive when hooked up, then you're either not getting power, the drive is not spinning (dead), or you have a bad connection/input.
Nov 17, 2012 | Iomega 500GB Ultramax HD Esata/usb/fw 500...
What do i do if my hard drive is only saying unsupported format on the screen ?
Did you format this drive using Mac computer? The only time when the computer will display "Invalid or Unsupported format" is when Windows do not recognize the file format that you are using on the external drive. If this is the case you may need to format the drive, but backup your files first before doing that.
Aug 27, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
When I loade my pictures they dont show it says Unsupported Media Format
It either means that your computer does not recognize that file format or you'll need to install the decoder for that. you can also set it up manually by going to the START > CONTROL PANEL > DEFAULT PROGRAMS > SET FILE ASSOCIATION > then look for the file extension like jpg, mpg, etc and set the program that will open that particular file.
Apr 27, 2011 | Computers & Internet
What does status code-68-cood36be mean . i have downloaded a video from my computer straight to my xbox but wont play because it said it unsupported please advise
This means that the file format you are trying to play is not supported or cannot be played by your console due to format restrictions. It means that the video has an invalid format not recognized by the console that is why it is not playing thus showing this error code.
May 10, 2010 | Microsoft Xbox Console
Computer not recognizing Dvd drive
Hi, Check the MS word / software file it works DVD drive, if it recognize there is no problem the drive and play CD - format files.
If not recognize, i found that DVD Lens not working what you can do DVD lens cleaner disc you found stores. Rgds, Manju
Jan 26, 2010 | Computers & Internet
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
Verbatim Insight 320gb Portable External Usb Hard Drive Model Is320 Logo
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
